cgal-discuss - Re: [cgal-discuss] Re: error related to QGLViewer
  • To:
  • Subject: Re: [cgal-discuss] Re: error related to QGLViewer
  • Date: Mon, 17 Oct 2011 13:45:53 -0700
The path to libqglviewer include files is invalid.
What is the value of QGLVIEWER_INCLUDE_DIR in the file CMakeCache.txt?
Note that QGLVIEWER_INCLUDE_DIR is correct if the file
QGLVIEWER_INCLUDE_DIR/QGLViewer/qglviewer.h should exist.
If QGLVIEWER_INCLUDE_DIR is incorrect, edit the file (or use cmake gui)
to set it correctly.
Sebastien.
On 10/17/2011 01:58 AM, jiju wrote:
Hi,
When I tried to build surface_mesher demo, I'm getting the followingerror
message:
c:\cgal-3.9\demo\surface_mesher\viewer.h(4) : fatal error C1083: Cannot open
include file: 'QGLViewer/qglviewer.h': Invalid argument
I've configured the demo by setting cmake variables corresponding to
qglviewer and also I've added qglviewerroot environment variable.
Earlier, when i configured the demo using cmake I had obtained some warning
messages like:
WARNING: Target "Surface_mesher" requests linking to directory
"C:/libQGLViewer-2.3.10/QGLViewer/release". Targets may link only to
libraries. CMake is dropping the item.
what could be the problem?
Jiju
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/error-related-to-QGLViewer-tp3908960p3911428.html
