- To:
- Subject: [cgal-discuss] do_intersect visitor pattern
- Date: Mon, 17 Oct 2011 19:45:32 -0700 (PDT)
I have a list of polygons, and I want to check whether any of them intersect
with others or not ( predicate is sufficient, I just want to know whether A
polygon intersects with B, that's it).
And since I have a list of polygons, I want to use do_intersect and I want
to keep the index of the intersected polygons. It would be great if
do_intersect also accepts a functor, that is called when an intersection
happens, so that I can store the index of the polygon somewhere.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/do-intersect-visitor-pattern-tp3914108p3914108.html
- [cgal-discuss] do_intersect visitor pattern, Graviton, 10/18/2011
- Re: [cgal-discuss] do_intersect visitor pattern, Sebastien Loriot (GeometryFactory), 10/18/2011
- [cgal-discuss] Re: do_intersect visitor pattern, Graviton, 10/18/2011
- Re: [cgal-discuss] Re: do_intersect visitor pattern, Sebastien Loriot (GeometryFactory), 10/18/2011
