- To:
- Subject: [cgal-discuss] Re: do_intersect visitor pattern
- Date: Mon, 17 Oct 2011 23:28:01 -0700 (PDT)
Thanks, but won't that be a bit slow? Because for every intersection, you need to box_self_intersection_d once, and then do_intersect a second time, would that means that I am actually computing the intersection one more time than necessary?
On Tue, Oct 18, 2011 at 2:20 PM, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
On 10/17/2011 11:15 PM, Graviton wrote:The call to do_intersect must be done by you in the functor.> <http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d_ref/Function_box_self_intersection_d.html#Cross_link_anchor_1717> does.
> Hello, I read your link, and look back at the do_intersection API, I
> don't think do_intersection actually takes in a functor, just like how
> box_self_intersection_d> Or is it that one needs to use box_self_intersection_d> <http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d_ref/Function_box_self_intersection_d.html#Cross_link_anchor_1717> in> this case? But isn't box_self_intersection_d> <http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d_ref/Function_box_self_intersection_d.html#Cross_link_anchor_1717> is> supposed to be used for proximity computation, and used when there are
> complicated geometries?
The functor is called each time the bounding boxes intersect.
Sebastien.> cgal-discuss] <[hidden email]
> On Tue, Oct 18, 2011 at 1:13 PM, Sebastien Loriot (GeometryFactory) [via> ------------------------------------------------------------------------> </user/SendEmail.jtp?type=node&node=3914328&i=0>> wrote:
> Have a look at this chapter:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d/Chapter_main.html
> and in particular the following example you can adapt
> to polygon. Note that you can also pass a functor instead
> of a function.
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d/Chapter_main.html#Section_62.5
>> > Sent from the cgal-discuss mailing list archive at Nabble.com.
> Sebastien.
> On 10/17/2011 07:45 PM, Graviton wrote:
> > I have a list of polygons, and I want to check whether any of
> them intersect
> > with others or not ( predicate is sufficient, I just want to know
> whether A
> > polygon intersects with B, that's it).
> > And since I have a list of polygons, I want to use do_intersect
> and I want
> > to keep the index of the intersected polygons. It would be great if
> > do_intersect also accepts a functor, that is called when an
> intersection
> > happens, so that I can store the index of the polygon somewhere.
> > View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/do-intersect-visitor-pattern-tp3914108p3914108.html
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
>> If you reply to this email, your message will be added to the> ------------------------------------------------------------------------
> discussion below:
> http://cgal-discuss.949826.n4.nabble.com/do-intersect-visitor-pattern-tp3914108p3914272.html
> To unsubscribe from do_intersect visitor pattern, click here.
> View this message in context: Re: do_intersect visitor pattern
> <http://cgal-discuss.949826.n4.nabble.com/do-intersect-visitor-pattern-tp3914108p3914328.html>> Sent from the cgal-discuss mailing list archive> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
http://cgal-discuss.949826.n4.nabble.com/do-intersect-visitor-pattern-tp3914108p3914337.htmlIf you reply to this email, your message will be added to the discussion below:To unsubscribe from do_intersect visitor pattern, click here.
- [cgal-discuss] do_intersect visitor pattern, Graviton, 10/18/2011
- Re: [cgal-discuss] do_intersect visitor pattern, Sebastien Loriot (GeometryFactory), 10/18/2011
- [cgal-discuss] Re: do_intersect visitor pattern, Graviton, 10/18/2011
- Re: [cgal-discuss] Re: do_intersect visitor pattern, Sebastien Loriot (GeometryFactory), 10/18/2011
