- To:
- Subject: Re: [cgal-discuss] Triangulation_3 Example execution problem
- Date: Thu, 20 Oct 2011 10:52:16 +0200
On mercredi 19 octobre 2011 07:29:32 Terence wrote:
> hi all, I have problem in running the demo of Triangulation_3 example,
> when I run the T3_Demo.exe, an error of "Entry point for function
> _Z5qFreePV not found in QtCore4.dll. Can someone help me in solving the
> problem ?Thanks.
Search for the executable depends.exe, shipped in Visual Studio. You can also
find it on the web.
Then launch depends.exe and open the file T3_Demo.exe with it. You will find
out that the QtCore4.dll that is loaded at runtime comes from a different
version of Qt4 that the one you used to build the demo. Probably your PATH
environment variable is poluted by a directory that contains some (old) Qt4
DLLs.
You can workaround that issue by manually copying the right versions of
Qt4Core.dll and Qt4Gui.dll into the directory when lies T3_Demo.exe.
Laurent Rineau, PhD
- [cgal-discuss] Triangulation_3 Example execution problem, Terence, 10/19/2011
- [cgal-discuss] Re: Triangulation_3 Example execution problem, Terence, 10/20/2011
- Re: [cgal-discuss] Triangulation_3 Example execution problem, Laurent Rineau (GeometryFactory), 10/20/2011
- Re: [cgal-discuss] Re: Triangulation_3 Example execution problem, Laurent Rineau (GeometryFactory), 10/20/2011
