- To:
- Subject: Re: [cgal-discuss] Re: Triangulation_3 Example execution problem
- Date: Thu, 20 Oct 2011 14:25:56 +0200
On jeudi 20 octobre 2011 13:03:46 Terence wrote:
> Thanks, I have another problem after fixing the execution problem,
How have you "fixed" it?
> after
> successful compile the demonstration and run T3_demo.exe. the following
> information obtained:
> QWidget: Must constrcut a QApplication before a QPaintDevice
> How to fix it? Thanks!
Same answer: use depends.exe to understand what DLLs are actually loaded at
runtime.
You are probably mixing Qt4 DLLs from various Qt4 installations, with
different versions.
Laurent Rineau, PhD
- [cgal-discuss] Triangulation_3 Example execution problem, Terence, 10/19/2011
- [cgal-discuss] Re: Triangulation_3 Example execution problem, Terence, 10/20/2011
- Re: [cgal-discuss] Triangulation_3 Example execution problem, Laurent Rineau (GeometryFactory), 10/20/2011
- Re: [cgal-discuss] Re: Triangulation_3 Example execution problem, Laurent Rineau (GeometryFactory), 10/20/2011
