cgal-discuss - [cgal-discuss] Box_with_handle_d cannot take integer as handle?
  • To:
  • Subject: [cgal-discuss] Box_with_handle_d cannot take integer as handle?
  • Date: Mon, 24 Oct 2011 21:41:01 -0700 (PDT)
I have this code-- it is modified from the
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d/Chapter_main.html#Section_62.5
example here.
#include <CGAL/intersections.h>
#include <CGAL/point_generators_3.h>
#include <CGAL/Bbox_3.h>
#include <CGAL/box_intersection_d.h>
#include <CGAL/function_objects.h>
#include <CGAL/Join_input_iterator.h>
#include <CGAL/algorithm.h>
#include <vector>
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef Kernel::Point_3 Point_3;
typedef Kernel::Triangle_3 Triangle_3;
typedef std::vector<Triangle_3> Triangles;
typedef Triangles::iterator Iterator;
typedef CGAL::Box_intersection_d::Box_with_handle_d<double,3,int> Box;
Triangles triangles; // global vector of all triangles
// callback function that reports all truly intersecting triangles
void report_inters( const Box& a, const Box& b) {
/* std::cout << "Box " << (a.handle() - triangles.begin()) << " and "
<< (b.handle() - triangles.begin()) << " intersect";
if ( ! a.handle()->is_degenerate() && ! b.handle()->is_degenerate()
&& CGAL::do_intersect( *(a.handle()), *(b.handle()))) {
std::cout << ", and the triangles intersect also";
std::cout << '.' << std::endl;*/
int main() {
// Create 10 random triangles
typedef CGAL::Random_points_in_cube_3<Point_3> Pts;
typedef CGAL::Creator_uniform_3< Point_3, Triangle_3> Creator;
typedef CGAL::Join_input_iterator_3<Pts,Pts,Pts,Creator> Triangle_gen;
Pts points( 1); // in centered cube [-1,1)^3
Triangle_gen triangle_gen( points, points, points);
CGAL::copy_n( triangle_gen, 10, std::back_inserter(triangles));
// Create the corresponding vector of bounding boxes
std::vector<Box> boxes;
for ( Iterator i = triangles.begin(); i != triangles.end(); ++i)
boxes.push_back( Box( i->bbox(), 0));
// Run the self intersection algorithm with all defaults
CGAL::box_self_intersection_d( boxes.begin(), boxes.end(),
report_inters);
return 0;
The only difference is this line
The handle is now an int, instead of a Iterator.
And the compilation error I get is illegal indirection, which I think is
quite weird.
Any idea?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Box-with-handle-d-cannot-take-integer-as-handle-tp3935631p3935631.html
