- To:
- Subject: Re: [cgal-discuss] Problems with a 3D Triangulation
- Date: Thu, 27 Oct 2011 19:41:34 +0200
Hi guys:
Thank you for all, I have solved almost all my problems with
triangulations, but I have another questions about Triangulations:
- When I iterate the cells of my triangulation, there is a vertex with
value of cordinates very big "infinite_vertex". In this case, the
cells with this vertex must be excluded from the triangulation? Why
this vertex is included in my triangulation? What can I do with these
cells which contain this vertex?
The second step of my simulations is to work with these cells, but I
can't do it with this infinite vertex included.
- My second question is the follows:
I have a map of cells (keys) (I have more than 10 000 000 of cells)
and a list of integers (values), where I will store each cells and the
number of vertices respect to the another list. When I execute the
following code:
std::map<Cell_handle, std::list<int>> Cells;
for(All_cells_iterator cit = T.cells_begin(), end = T.cells_end(); cit
!= end; cit)
int myints[] =
{Vertices.find(cit->vertex(0))->second,Vertices.find(cit->vertex(1))->second,Vertices.find(cit->vertex(2))->second,Vertices.find(cit->vertex(3))->second};
Cells.insert(std::make_pair(cit, list<int>(myints, myints
sizeof(myints)/sizeof(int))));
and after several iterations I have this error:
Microsoft C Exception: std::bad_alloc
Maybe these questions are trivial ones, but I cant solve them.
Thank you for all, I appreciate a lot your help
Best Regards
Juan Carlos
On Thu, Oct 27, 2011 at 9:00 AM, Marc Glisse
wrote:
> On Thu, 27 Oct 2011, Juan Carlos Lopez Alfonso wrote:
>> Thank you for your answer, but I have created a new set of point where
>> I dont have repeated points, I have exported the set of point from
>> matlab and I am using the unique function of matlab (unique) to ensure
>> the uniqueness of each point in my list. For these reason I have a new
>> list of points, where each point appear only once.
> matlab prints the coordinates with a very small precision, so 2 different
> points in matlab might be written the same in the exported file. Maybe you
> could change the setting in matlab to make it print the coordinates with
> more precision?
> Marc Glisse
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: [cgal-discuss] Problems with a 3D Triangulation, (continued)
- Re: [cgal-discuss] Problems with a 3D Triangulation, Marc Glisse, 10/25/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Andreas Fabri, 10/25/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Juan Carlos Lopez Alfonso, 10/25/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Monique Teillaud, 10/25/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Juan Carlos Lopez Alfonso, 10/27/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Marc Glisse, 10/27/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Daniel Duque, 10/27/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Sebastien Loriot (GeometryFactory), 10/27/2011
