cgal-discuss - Re: [cgal-discuss] Problems with a 3D Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Problems with a 3D Triangulation
  • Date: Tue, 25 Oct 2011 21:40:38 +0200
Hi Juan Carlos,
On my Intel Core 2 duo 2.8 Ghz your program takes 37 min.
And I bring it down to 5 min with our local fix.
If it takes hours on your machine you probably do something
wrong.
best regards,
andreas
On 25/10/2011 15:15, Juan Carlos Lopez Alfonso wrote:
Hi:
Thank again for your help. In these links you can download the
example code (example.cpp) and the data file (either in .rar or .txt),
with the set of points, where in the first line of this file is the
number of points and in the other lines the listed set of points. If
you didn't download these files, please tell me where I can put them
in order that you can prove my example and give me any suggestion.
http://dl.dropbox.com/u/2516160/example.cpp
http://dl.dropbox.com/u/2516160/treatmentPoints.rar
http://dl.dropbox.com/u/2516160/treatmentPoints.txt
In my case, I am sure that I have several group of points with the
same x,y and only varying the z (you can see my file of points and is
very easy see that), because I am trying to triangulate a TAC of a
radiotherapy patient with the defined organs involved. I have for all
slices of a TAC diferent points with the same value of x,y only
varying the coordinate z. I am using a set of points of a radiotherapy
treatment plan and from different slice of the TAC in 2D I am forming
a 3D domain with these points. For this reason, I have almost the same
points x,y only varying the z for each slice of the TAC.
Best Regards from madrid and waiting for your answer
Juan Carlos
On Tue, Oct 25, 2011 at 2:23 PM, Andreas Fabri
wrote:
If you want you can post your code,
and put the data on a server so that we can
download it and try to reproduce/fix the problem.
It might also be the data. We had a user where
all points where on a 3D grid, or all points
where organized in k groups with identical x,y
and only varying z coordinate, where CGAL was
rather slow. We have a not yet released solution
for that.
best regards,
andreas
On 25/10/2011 14:14, Juan Carlos Lopez Alfonso wrote:
Hi:
Thank you again for your answer. Yes, you are right I am using
Exact_predicates_inexact_constructions_kernel. For example with 4618
points, when I use the Triangulation_3 the triangulation is computed
in 3 sec and with Delaunay_triangulation_3 in 20 sec.
But my real simulation is with more than 3500 000 of points and 3.5
hours is much time for my time real simulations only computing the
triangulation.
Any comment about how I can do to improve my simulation time?
Best regards agian, and sorry for your time
Juan Carlos
On Tue, Oct 25, 2011 at 1:49 PM, Marc
Glisse<>
wrote:
On Tue, 25 Oct 2011, Juan Carlos Lopez Alfonso wrote:
Thank you for your answer. About my second question about the
computing time, you say that the problem would be my memory, but could
you tell me any suggestion about how I can obtain better performance?
I am using CGAL 3.9 with visual studio 2010, in a Pentium(R) Dual-Core
CPU 2.10 GHz and 2GB RAM. On the other hand, I have the maximum value
(8190 MB) of virtual memory in my windows 7 option.
To check whether it is memory, you should try with fewer points and see
how
the running time evolves.
But first:
* I assume you are using Exact_predicates_inexact_constructions_kernel,
right?
* Are you using Triangulation_3? Did you try Delaunay_triangulation_3?
Marc Glisse
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
Andreas Fabri, PhD
