- To:
- Subject: Re: [cgal-discuss] convex hull, indices of extreme points
- Date: Sat, 29 Oct 2011 23:16:57 +0200
On 29/10/2011 22:20,
wrote:
Dear CGAL community,
following
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Convex_hull_2/Chapter_main.html#Section_15.3
to perform a convec hull computation was quite simple and straight forward -
thank you very much.
Starting from there: Is it possible to receive the indices of the resulting
extreme points in the original set of points?
Thanks a lot,
Thomas
The traits classes are all about this kind of plumbing.
Instead of the transform iterator you could have first
created a container with point/index pairs.
See the attached code.
best regards,
andreas
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/convex_hull_2.h> #include <vector> #include <boost/iterator/transform_iterator.hpp> typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef K::Point_2 Point_2; typedef std::pair<Point_2,int> PointWithIndex; typedef std::vector<Point_2> Points; class pwi { private: const Point_2* base; public: typedef PointWithIndex result_type; pwi(): base(0) {} pwi(const Point_2* base): base(base) {} PointWithIndex operator()(const Point_2& p) const { return PointWithIndex(p, &p-base); } }; typedef boost::transform_iterator<pwi, Points::iterator> Iterator; struct My_traits { typedef PointWithIndex Point_2; struct Less_xy_2 { bool operator()(const Point_2& p, const Point_2& q) const { K::Less_xy_2 less_xy_2; return less_xy_2(p.first, q.first); } }; struct Left_turn_2 { bool operator()(const Point_2& p, const Point_2& q, const Point_2& r) const { K::Left_turn_2 left_turn_2; return left_turn_2(p.first, q.first, r.first); } }; struct Equal_2 { bool operator()(const Point_2& p, const Point_2& q) const { K::Equal_2 equal_2; return equal_2(p.first, q.first); } }; Equal_2 equal_2_object() const { return Equal_2();} Less_xy_2 less_xy_2_object() const { return Less_xy_2();} Left_turn_2 left_turn_2_object() const { return Left_turn_2();} }; int main() { Points points; std::vector<PointWithIndex> result; points.push_back(Point_2(0,0)); points.push_back(Point_2(10,0)); points.push_back(Point_2(6,5)); points.push_back(Point_2(4,6)); points.push_back(Point_2(10,10)); points.push_back(Point_2(4,1)); Iterator it(points.begin(), pwi(&points[0])), end(points.end(), pwi()); CGAL::ch_graham_andrew( it, end, std::back_inserter(result),My_traits() ); std::cout << result.size() << " points on the convex hull" << std::endl; for(std::vector<PointWithIndex>::iterator it = result.begin(); it != result.end(); ++it){ std::cout << it->first << " | " << it->second << std::endl; } return 0; }
- [cgal-discuss] convex hull, indices of extreme points, mail, 10/29/2011
- Re: [cgal-discuss] convex hull, indices of extreme points, Andreas Fabri, 10/29/2011
- Re: [cgal-discuss] convex hull, indices of extreme points, Thomas Ruland, 10/30/2011
