- To:
- Subject: Re: [cgal-discuss] Re: Bug for CGAL?
- Date: Fri, 04 Nov 2011 08:22:38 +0100
This is a problem in the demo only.
Try patching include/CGAL/Qt/PainterOstream.h
like this:
@@ -156,6 +156,7 @@
const Point_2 proj_source = line.projection(source);
const Point_2 proj_target = line.projection(target);
+ if (CGAL::collinear(proj_source,proj_target,center)) return;
const Point_2 intersection = circumcenter(proj_source,
proj_target,
center);
Sebastien.
Hailong Yao wrote:
Dear all,
It seems I have not received any reply on this thread.
I thecked the CGAL manual, is there a constraint for segment Voronoi diagrams that no four points are co-circular? If so, is it difficult to solve this issue? In my inputs, there are many cases where four points are co-circular. How can I solve this problem? Any comments or suggestions? Thanks very much!
Thanks,
Hailong
On Mon, Oct 31, 2011 at 10:04 PM, Hailong Yao < <mailto:>> wrote:
Dear all,
I am trying a demo of the CGAL in "Segment_Delaunay_graph_2", I can
launch the demo and draw segments in the window to get the correct
segment voronoi graphs for most cases. But when I draw three
parallel vertical segments, the program crashes. Anyone has met with
this problem? Thanks very much!
Thanks,
Hailong
- [cgal-discuss] Re: Bug for CGAL?, Hailong Yao, 11/04/2011
- Re: [cgal-discuss] Re: Bug for CGAL?, Sebastien Loriot (GeometryFactory), 11/04/2011
- Re: [cgal-discuss] Re: Bug for CGAL?, Hailong Yao, 11/05/2011
