cgal-discuss - Re: [cgal-discuss] Re: Bug for CGAL?
  • To:
  • Subject: Re: [cgal-discuss] Re: Bug for CGAL?
  • Date: Sat, 5 Nov 2011 14:12:04 +0800
Thanks very much! It works!
Thanks again,
Hailong
On Fri, Nov 4, 2011 at 3:22 PM, Sebastien Loriot (GeometryFactory) <> wrote:
This is a problem in the demo only.
Try patching include/CGAL/Qt/PainterOstream.h
like this:
@@ -156,6 +156,7 @@
    const Point_2 proj_source = line.projection(source);
    const Point_2 proj_target = line.projection(target);
+    if (CGAL::collinear(proj_source,proj_target,center)) return;
    const Point_2 intersection = circumcenter(proj_source,
                                                proj_target,
                                                center);
Sebastien.
Hailong Yao wrote:
Dear all,
 It seems I have not received any reply on this thread.
 I thecked the CGAL manual, is there a constraint for segment Voronoi diagrams that no four points are co-circular? If so, is it difficult to solve this issue? In my inputs, there are many cases where four points are co-circular. How can I solve this problem? Any comments or suggestions? Thanks very much!
 Thanks,
Hailong
On Mon, Oct 31, 2011 at 10:04 PM, Hailong Yao < <mailto:>> wrote:
   Dear all,
        I am trying a demo of the CGAL in "Segment_Delaunay_graph_2", I can
   launch the demo and draw segments in the window to get the correct
   segment voronoi graphs for most cases. But when I draw three
   parallel vertical segments, the program crashes. Anyone has met with
   this problem? Thanks very much!
        Thanks,
   Hailong
