cgal-discuss - [cgal-discuss] Can CGAL handle with meshes with errors?
  • To:
  • Subject: [cgal-discuss] Can CGAL handle with meshes with errors?
  • Date: Fri, 4 Nov 2011 06:14:01 -0700 (PDT)
Hi, I met some polygonal meshes with errors in my project. The vertex indices
of one face may contain duplicated numbers. For example, after exporting to
a *.obj file, one line may be like:
f 193 25 75 113 149 185 75 25 49
I've attached the problematic obj file.
If reading in this file using CGAL and saving it to the Polyhedron_3 data
structure, an error will be reported.
However when I use some other tools, for example, the MeshLab which uses the
vcg as basis data structure, a valid triangular mesh can be obtained, and
the error face becomes a set of valid triangles:
f 25 149 193
f 193 149 185
f 193 185 49
f 49 185 75
f 49 75 25
f 25 75 113
f 25 113 149
I'm just wondering:
1 Whether it's possible to handle this problem using CGAL
2 If not, does anyone has idea on how to solve this problem or how vcg
solved this problem please?
Thanks very much!
http://cgal-discuss.949826.n4.nabble.com/file/n3990013/carve_csg_out.obj
carve_csg_out.obj
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Can-CGAL-handle-with-meshes-with-errors-tp3990013p3990013.html
