- To:
- Subject: Re: [cgal-discuss] CGAL and Qt
- Date: Fri, 4 Nov 2011 17:08:31 +0100
On vendredi 04 novembre 2011 16:23:06 RossH wrote:
> I'm currently working on drawing walks on Triangulations using Qt and CGAL.
> This involves drawing a triangulation and then redrawing certain triangles
> in different colours to show that they have been visited.
> An older version of the CGAL manual seems to describe a procedure for doing
> this using* Qt_widget *:
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Qt_widget/Chapter_main.
> html
> .html ).
CGAL Qt_widget was a library using Qt3. Qt3 is deprecated by Qt4 for a long
time, and the CGAL project decided to deprecate CGAL Qt_widget as well.
> However this seems to differ from the descriptions given in the newer
> manual:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/GraphicsView/Chapter
> _main.html
> r_main.html )
> Which is based on *QGraphicsView*.
That uses Qt4 QGraphicsView.
> So my question is: Is Qt_widget depreciated? If yes, then is there a "nice"
> way to redraw individual triangles from a TriangulationGraphicsItem?
You can use QGraphicsView directly by adding some QGraphicsPolygonItem
yourself to the scene. You can even mix that with a display of a
CGAL::TriangulationGraphicsItem.
See:
http://doc.qt.nokia.com/latest/graphicsview.html
http://doc.qt.nokia.com/latest/qgraphicspolygonitem.html
Laurent Rineau, PhD
- [cgal-discuss] CGAL and Qt, RossH, 11/04/2011
- Re: [cgal-discuss] CGAL and Qt, Laurent Rineau (GeometryFactory), 11/04/2011
