- To:
- Subject: Re: [cgal-discuss] about Alpha_Shape
- Date: Mon, 14 Nov 2011 14:24:22 +0100
Juan Carlos Lopez Alfonso wrote:
Hi all,
There are any form to use 3D Alpha_Shapes with a general triangulation like Triangulation_3? because Delaunay triangulation or Regular triangulation move my points in order to obtain a linear approximation of the original shape and I need to have a triangulation from a fix set of points.
Nor Delaunay, nor Regular triangulation moves your points. It's building
a triangulation on top of your point set, so what do you mean?
On the other hand, I have created a Delaunay Triangulation (Delaunay dt;) from a set of points and when I try to create an alpha_shape (Alpha_shape_3 as(dt);) I have the following error: CGAL::Assertion_exception !!!
Did you read this?
http://www.cgal.org/FAQ.html#inexact_NT
If yes, showing some code might help giving you an answer.
Sebastien.
Best regrads and thank in advance
Juan Carlos
- [cgal-discuss] about Alpha_Shape, Juan Carlos Lopez Alfonso, 11/14/2011
- Re: [cgal-discuss] about Alpha_Shape, Sebastien Loriot (GeometryFactory), 11/14/2011
- Re: [cgal-discuss] about Alpha_Shape, Juan Carlos Lopez Alfonso, 11/14/2011
- Re: [cgal-discuss] about Alpha_Shape, Sebastien Loriot (GeometryFactory), 11/15/2011
