- To:
- Subject: Re: [cgal-discuss] about Alpha_Shape
- Date: Mon, 14 Nov 2011 14:42:31 +0100
Hi Sebastien:
First of all thank you for your answer and your comments.
In these links you can find my file of set of points and the code of my example, which is simple and exactly as the example "42.5.2 Building Basic Alpha Shapes for Many Points" on the Alpha_Shape charapter of Cgal documentation.
About my first question, I beleived that with alpha_shape was obtained an approximated surface of my set of points. In my problem I have a set of points and I need that my resultant triangulation has the exactly same set of points, in the surface and in the interior (I want to create a triangulation of a head with their interior organs).
Best regards and waiting for your help
Juan carlos
On Mon, Nov 14, 2011 at 2:24 PM, Sebastien Loriot (GeometryFactory) <> wrote:
Juan Carlos Lopez Alfonso wrote:Nor Delaunay, nor Regular triangulation moves your points. It's building
Hi all,
There are any form to use 3D Alpha_Shapes with a general triangulation like Triangulation_3? because Delaunay triangulation or Regular triangulation move my points in order to obtain a linear approximation of the original shape and I need to have a triangulation from a fix set of points.
a triangulation on top of your point set, so what do you mean?Did you read this?
On the other hand, I have created a Delaunay Triangulation (Delaunay dt;) from a set of points and when I try to create an alpha_shape (Alpha_shape_3 as(dt);) I have the following error: CGAL::Assertion_exception !!!
http://www.cgal.org/FAQ.html#inexact_NT
If yes, showing some code might help giving you an answer.
Sebastien.--
Best regrads and thank in advance
Juan Carlos
- [cgal-discuss] about Alpha_Shape, Juan Carlos Lopez Alfonso, 11/14/2011
- Re: [cgal-discuss] about Alpha_Shape, Sebastien Loriot (GeometryFactory), 11/14/2011
- Re: [cgal-discuss] about Alpha_Shape, Juan Carlos Lopez Alfonso, 11/14/2011
- Re: [cgal-discuss] about Alpha_Shape, Sebastien Loriot (GeometryFactory), 11/15/2011
