cgal-discuss - Re: [cgal-discuss] Question about win64 CGAL version
  • To:
  • Subject: Re: [cgal-discuss] Question about win64 CGAL version
  • Date: Wed, 16 Nov 2011 17:06:55 +0100
Hello,
The CGAL installer allows to download 32 and 64 bit versions of
the 3rd party libraries.
Note however that Qt4 is not officially supported on VC10 64bit.
andreas
On 16/11/2011 16:39, Vivien Clauzon wrote:
Hello,
I've just tried to use CGAL for a win64 visual studio 10 project and i'm
facing quite an issue. Indeed, allthough my project compiles and works
fine in 32 bits, I cannot get it to compile in 64 bits because of the
missing gmp and mpfr in CGAL-3.9\auxiliary\gmp\lib and the missing tauc
in CGAL-3.9\auxiliary\taucs.
I can find 64 bits pre build tauc binaries, or I can build it myself if
requiered, but I can't find a way to get 64 bits gmp and mpfr.
It seems that mpir (http://mpir.org/) can provide a solution but entry
points in mpir.lib and gmp.lib are differents as cgal is looking for
things like "__imp___gmpz_clear" while mpir is providing "__gmpz_clear".
Of course, in the documentation of CGAL, i can read :/
GmpandMpfrare libraries for multi precision integers and rational
numbers, and for multi precision floating point numbers./
/Cgalcombines floating point arithmetic with exact arithmetic, in order
to be efficient and reliable.Cgalhas a built-in number type for that,
butGmpandMpfrprovide a faster solution, and we recommend to use them./
/HavingGmpversion 4.2 or higher andMpfrversion 2.2.1 or higher installed
is recommended. These libraries can be obtained
fromhttp://gmplib.org/andhttp://www.mpfr.org/, respectively./
/As Visual C++is not properly supported by theGmpandMpfrprojects, we
provide precompiled versions ofGmpandMpfr, which can be downloaded with
the installerCGAL-3.9-Setup.exe./
and using the apropriate flag in CMAKE I was able to get CGAL working
without gmp in both 32 and 64 bits and finally link my project correctly.
Finaly my question is .... does someone have found a way to use gmp in
64 bits windows projects ?
Thanks in advance.
NUMTECH <http://www.numtech.fr> Vivien CLAUZON
Ingénieur d'études et de recherche
6, allée Alan Turing - BP 30242 - Parc Technologique de la Pardieu
63175 AUBIERE Cedex - FRANCE
Tél: 33 (0)4 73.28.75.95 - Fax: 33 (0)4.73.28.75.99
Web: http://www.numtech.fr
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
