- To:
- Subject: [cgal-discuss] not desired results with alpha_shape_3
- Date: Wed, 16 Nov 2011 17:19:18 +0100
Hi all:
I have an input set of points which is a close contours in parallel planes:
Why when I use the alpha shape class I obtain something like this:
when I want that the shape of the 3d-triangulation contour adjusts the shape of my set of points.
This is my code:
Best regards
Juan Carlos
- [cgal-discuss] not desired results with alpha_shape_3, Juan Carlos Lopez Alfonso, 11/16/2011
- Re: [cgal-discuss] not desired results with alpha_shape_3, Sebastien Loriot (GeometryFactory), 11/16/2011
