- To:
- Subject: Re: [cgal-discuss] bad_alloc Alpha_Shape
- Date: Thu, 17 Nov 2011 12:55:36 +0100
Hi Sebastien:
thank you for your answer.
I have resolved my problem with the RAM, today the personal of
my LAB have gave us more memory.
Best regards
Juan Carlos
On Wed, Nov 16, 2011 at 5:51 PM, Sebastien Loriot (GeometryFactory) <> wrote:
It is highly probable that you are running out of memory.
Check the memory usage will running the application.
How much RAM do you have?
Sebastien.--
Juan Carlos Lopez Alfonso wrote:
Hi:
I have a simple code where I try to use alpha_shape class. I have a list of points with more than 3 200 000 of points and when I execute this line:
Alpha_shape_3 as(L.begin(), L.end(), 0, Alpha_shape_3::REGULARIZED);
I have these exception: "bad_alloc". My questions is, Do this exception depend with the size of my data? because with less numbers of points I don't have this problem. I only use memory for my list of points.
Best Regards
Juan Carlos
- [cgal-discuss] bad_alloc Alpha_Shape, Juan Carlos Lopez Alfonso, 11/16/2011
- Re: [cgal-discuss] bad_alloc Alpha_Shape, Sebastien Loriot (GeometryFactory), 11/16/2011
- Re: [cgal-discuss] bad_alloc Alpha_Shape, Juan Carlos Lopez Alfonso, 11/17/2011
