cgal-discuss - [cgal-discuss] some problems using poisson_reconstruction_example.cpp
  • To:
  • Subject: [cgal-discuss] some problems using poisson_reconstruction_example.cpp
  • Date: Fri, 18 Nov 2011 18:49:51 +0100
Hi CGAL users:
I am trying to run the example:
examples/Surface_reconstruction_points_3/poisson_reconstruction_example.cpp
and I have the following compiled error (there are many, but I only will include here some of them):
1> LIBCMT.LIB (crt0init.obj): error LNK2005: already defined in MSVCRTD.lib ___xc_z (cinitexe.obj)
1> LIBCMT.LIB (mlock.obj): error LNK2005: already defined in MSVCRTD.lib __unlock (MSVCR100D.dll)
1> LIBCMT.LIB (mlock.obj): error LNK2005: already defined in MSVCRTD.lib __lock (MSVCR100D.dll)
1> LIBCMT.LIB (winxfltr.obj): error LNK2005: already defined in MSVCRTD.lib __XcptFilter (MSVCR100D.dll)
1> LIBCMT.LIB (crt0.obj): error LNK2005: already defined in MSVCRTD.lib _mainCRTStartup (crtexe.obj)
1> LIBCMT.LIB (errmode.obj): error LNK2005: already defined in MSVCRTD.lib ___set_app_type (MSVCR100D.dll)
1> LINK: warning LNK4098: predeterminada'MSVCRTD library 'conflicts with other libraries, library use / NODEFAULTLIB: library
1> LINK: warning LNK4098: predeterminada'LIBCMT library 'conflicts with other libraries, library use / NODEFAULTLIB: library
I have change all the compiler options related with multithread process and nothing at all. I also have installed and compiled the taucs library.
On the other hand, When I have varied the compiler options mentioned above I have the following error:
LINK: fatal error LNK1104: can not open file 'CGAL_Core-VC100-mt-sgd.lib'
Please, some help
Adam.
