- To:
- Subject: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN
- Date: Sun, 20 Nov 2011 18:15:24 +0800
> I Mark,
> Thanks for the report. I am surprised, because I use Qt-4.8 and
> boost-1.47, and the g++ compiler on Linux and I do not see that
> error. I would like to reproduce the bug before I apply you patch.
> - What version of Boost was involved? - And what version of mingw?
> - You talk about cross-compiling? What was the target-OS, and what
> was the host-OS?
Hi,
I encountered this problem, too. However, my compiler is VC90, with
Boost 1.48 and QT 4.7.4. And the error will spring up when compiling
using NMake Makefiles manner generated by CMake 2.8.
- [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Mark Brand, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Vivien Clauzon, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Mark Brand, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Panagiotis Foteinos, 11/18/2011
- Re: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/21/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Panagiotis Foteinos, 11/21/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, au9ustine, 11/20/2011
