- To:
- Subject: [cgal-discuss] MRI brain meshing
- Date: Thu, 8 Dec 2011 11:08:55 +0100
Dear ALL I attached in the mail a slice from the mri volume that I need to mesh. The slice has some 90 degree angles resulted from segmentation. I tried to use make_mesh_3 to generate tetrahedron for this but it does not work. I did not use any optimization in mesh criteria. |
fig5.pdf
Description: Adobe PDF document
DO I miss something in the delaunay triangulation. I thought yesterday that I should find away to control the divide and conquer during the mesh generation. but I am not sure if this is right or wrong although I do not have too much experience in the 3d delaunay triangulation. Regards
Elhassan Abdou
Computational Science master student Uppsala
- [cgal-discuss] MRI brain meshing, elhassan Abdou, 12/08/2011
- Re: [cgal-discuss] MRI brain meshing, Laurent Rineau (GeometryFactory), 12/08/2011
- Re: [cgal-discuss] MRI brain meshing, elhassan Abdou, 12/08/2011
