cgal-discuss - Re: [cgal-discuss] Re: Find all the intersection points between 2 line groups
  • To:
  • Subject: Re: [cgal-discuss] Re: Find all the intersection points between 2 line groups
  • Date: Thu, 08 Dec 2011 12:10:45 +0200
If you continue with the overlay operation, then perhaps you can reduce the overhead of constructing the arrangement from the mesh. More precisely, if the line segments of the mesh are pairwise disjoint in their interior, you can construct the arrangement efficiently using member functions of the arrangement data-structure,i.e., arr.insert_in_face_interior(), arr.insert_from_{left,right}_vertex, and arr.insert_between_vertices().
Quoting Graviton
Thanks, using the overlay is a good idea.
Now I want to throw one more information into the mix; what if, one of the
line group is actually a polygonal mesh? Anything we can exploit from the
mesh structure of this line, so that the whole process can be speed up?
On Thu, Dec 8, 2011 at 12:34 AM, Efraim Fogel [via cgal-discuss] <
wrote:
Using the a plane-sweep algorithm is probably the most efficient
approach. You are looking for something similar to the overlay
operation, but in your case you need only the intersections (not the
arrangements). Sometimes this is also referred to as red-blue
intersections.
The Sweep_line_2 component of CGAL is an algorithmic framework. A
concrete algorithm is implemented through a visitor. Unfortunately, we
haven't exposed the interface of the visitor yet. If you want to use
this component, you must do one of the following:
1. Use the overlay mechanism: Construct 2 arrangements, say A and B,
from the 2 sets of lines, respectively, and compute their overlay
using the overlay() function while using, what we call, an overlay
traits (the 3rd argument to the function). The answer to what you need
lies in this traits.
2. Change the visitor of the overlay (Arr_overlay_sl_visitor.h) to do
what you need.
Quoting Graviton <[hidden email]<http://user/SendEmail.jtp?type=node&node=4169572&i=0>>:
> I have two groups of line segments, and I want to find the intersection
> between them. I understand that one can use
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Sweep_line_2/Chapter_main.html
> sweep line algorithm to find all the intersection points within one
line
> groups. But now I have 2 line segment groups, and I want to find the
> intersection between line in Group A and line in Group B ( I don't want
the
> intersection point between line segments among group A and line segments
> among group B).
> Any idea how CGAL can help in this?
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Find-all-the-intersection-points-between-2-line-groups-tp4168063p4168063.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
If you reply to this email, your message will be added to the discussion
below:
http://cgal-discuss.949826.n4.nabble.com/Find-all-the-intersection-points-between-2-line-groups-tp4168063p4169572.html
To unsubscribe from Find all the intersection points between 2 line
groups, click here<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4168063&code=c29vbmh1aS5uZ3VAZ21haWwuY29tfDQxNjgwNjN8NDk0OTIzNDUy>
NAML<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.InstantMailNamespace&breadcrumbs=instant+emails%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Find-all-the-intersection-points-between-2-line-groups-tp4168063p4171393.html
