cgal-discuss - Re: [cgal-discuss] Problem in compiling simple CGAL programs
  • To:
  • Subject: Re: [cgal-discuss] Problem in compiling simple CGAL programs
  • Date: Wed, 14 Dec 2011 23:09:00 +0530
Thanks Philipp I am using Netbeans IDE can you provide me some help to how to link CGAL library to it
On Wed, Dec 14, 2011 at 6:26 PM, Philipp Moeller <> wrote:
Hi,
looks like you are not linking to the CGAL libraries correctly. Consult your IDE
documentation how to setup the linking process. CGAL also provides a
script to generate a basic CMakeLists.txt file for a small project which
in turn can generate a Makefile. Your IDE manual should have information
how to create a new project from existing sources using a Makefile.
Philipp
anil <> writes:
> Hello,
> I am a new CGAL user. I am trying to run this simple program using NETBEANS
> but it is giving error i am not getting whether it is a CGAL configuration
> problem or the program is wrong.
> #include <iostream>
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/convex_hull_2.h>
> #include <vector>
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef K::Point_2 Point_2;
> int main() {
>     Point_2 points[5] = { Point_2(0,0), Point_2(10,0),
> Point_2(10,10),Point_2(6,5),Point_2(4,1) };
>     std::vector<Point_2> result;
>     CGAL::convex_hull_2( points, points+5, std::back_inserter(result) );
>     std::cout << result.size() << " points on the convex hull\n";
>     return 0;
> Error:---------------
> /usr/bin/make -f nbproject/Makefile-Debug.mk SUBPROJECTS= .build-conf
> make[1]: Entering directory `/home/mustang/NetBeansProjects/CHull'
> /usr/bin/make  -f nbproject/Makefile-Debug.mk dist/Debug/GNU-Linux-x86/chull
> make[2]: Entering directory `/home/mustang/NetBeansProjects/CHull'
> mkdir -p build/Debug/GNU-Linux-x86
> rm -f build/Debug/GNU-Linux-x86/main.o.d
> g++ -ICGAL   -c -g -MMD -MP -MF build/Debug/GNU-Linux-x86/main.o.d -o
> build/Debug/GNU-Linux-x86/main.o main.cpp
> mkdir -p dist/Debug/GNU-Linux-x86
> g++ -ICGAL    -o dist/Debug/GNU-Linux-x86/chull
> build/Debug/GNU-Linux-x86/main.o: In function `Gmpq_rep':
> /usr/local/include/CGAL/GMP/Gmpq_type.h:50: undefined reference to
> `__gmpq_init'
> build/Debug/GNU-Linux-x86/main.o: In function `~Gmpq_rep':
> /usr/local/include/CGAL/GMP/Gmpq_type.h:51: undefined reference to
> `__gmpq_clear'
> build/Debug/GNU-Linux-x86/main.o: In function `Gmpq':
> /usr/local/include/CGAL/GMP/Gmpq_type.h:132: undefined reference to
> `__gmpq_set_d'
> /usr/local/include/CGAL/GMP/Gmpq_type.h:131: undefined reference to
> `CGAL::assertion_fail(char const*, char const*, int, char const*)'
> `CGAL::Gmpq::operator==(CGAL::Gmpq const&) const':
> /usr/local/include/CGAL/GMP/Gmpq_type.h:193: undefined reference to
> `__gmpq_equal'
> `CGAL::Gmpq::operator<(CGAL::Gmpq const&) const':
> /usr/local/include/CGAL/GMP/Gmpq_type.h:194: undefined reference to
> `__gmpq_cmp'
> `CGAL::Gmpq::operator-=(CGAL::Gmpq const&)':
> /usr/local/include/CGAL/GMP/Gmpq_type.h:286: undefined reference to
> `__gmpq_sub'
> `CGAL::Gmpq::operator*=(CGAL::Gmpq const&)':
> /usr/local/include/CGAL/GMP/Gmpq_type.h:296: undefined reference to
> `__gmpq_mul'
> build/Debug/GNU-Linux-x86/main.o: In function `Handle':
> /usr/local/include/CGAL/Handle.h:54: undefined reference to
> `CGAL::precondition_fail(char const*, char const*, int, char const*)'
> build/Debug/GNU-Linux-x86/main.o: In function `bool
> CGAL::get_certain<bool>(CGAL::Uncertain<bool>)':
> /usr/local/include/CGAL/Uncertain.h:205: undefined reference to
> build/Debug/GNU-Linux-x86/main.o: In function `Uncertain':
> /usr/local/include/CGAL/Uncertain.h:103: undefined reference to
> build/Debug/GNU-Linux-x86/main.o: In function `Interval_nt':
> /usr/local/include/CGAL/Interval_nt.h:88: undefined reference to
> build/Debug/GNU-Linux-x86/main.o: In function `Test_runtime_rounding_modes':
> /usr/local/include/CGAL/Interval_nt.h:158: undefined reference to
> /usr/local/include/CGAL/Interval_nt.h:160: undefined reference to
> `std::back_insert_iterator<std::vector&lt;CGAL::Point_2&lt;CGAL::Epick>,
> std::allocator<CGAL::Point_2&lt;CGAL::Epick> > > >
> CGAL::ch_akl_toussaint<CGAL::Point_2&lt;CGAL::Epick>*,
> std::allocator<CGAL::Point_2&lt;CGAL::Epick> > > >,
> CGAL::Epick>(CGAL::Point_2<CGAL::Epick>*, CGAL::Point_2<CGAL::Epick>*,
> std::allocator<CGAL::Point_2&lt;CGAL::Epick> > > >, CGAL::Epick const&)':
> /usr/local/include/CGAL/Convex_hull_2/ch_akl_toussaint_impl.h:131: undefined
> reference to `CGAL::postcondition_fail(char const*, char const*, int, char
> const*)'
> `CGAL::Tee_for_output_iterator<std::back_insert_iterator&lt;std::vector&lt;CGAL::Point_2&lt;CGAL::Epick>,
> CGAL::Point_2<CGAL::Epick> >
> CGAL::ch__ref_graham_andrew_scan<__gnu_cxx::__normal_iterator<CGAL::Point_2&lt;CGAL::Epick>*,
> std::vector<CGAL::Point_2&lt;CGAL::Epick>,
> CGAL::Point_2<CGAL::Epick> >,
> CGAL::Epick>(__gnu_cxx::__normal_iterator<CGAL::Point_2&lt;CGAL::Epick>*,
> CGAL::Point_2<CGAL::Epick> >&, CGAL::Epick const&)':
> /usr/local/include/CGAL/Convex_hull_2/ch_graham_andrew_impl.h:146: undefined
> reference to `CGAL::precondition_fail(char const*, char const*, int, char
> const*)'
> /usr/local/include/CGAL/Convex_hull_2/ch_graham_andrew_impl.h:147: undefined
> const*)'
> /usr/local/include/CGAL/Convex_hull_2/ch_graham_andrew_impl.h:150: undefined
> const*)'
> /usr/local/include/CGAL/Convex_hull_2/ch_graham_andrew_impl.h:180: undefined
> reference to `CGAL::assertion_fail(char const*, char const*, int, char
> const*)'
> build/Debug/GNU-Linux-x86/main.o: In function `CGAL::Sign
> CGAL::get_certain<CGAL::Sign>(CGAL::Uncertain<CGAL::Sign>)':
> collect2: ld returned 1 exit status
> make[2]: *** [dist/Debug/GNU-Linux-x86/chull] Error 1
> make[2]: Leaving directory `/home/mustang/NetBeansProjects/CHull'
> make[1]: *** [.build-conf] Error 2
> make[1]: Leaving directory `/home/mustang/NetBeansProjects/CHull'
> make: *** [.build-impl] Error 2
> BUILD FAILED (exit value 2, total time: 8s)
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Problem-in-compiling-simple-CGAL-programs-tp4194542p4194542.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
Anil Kumar Sahu
Pursuing M. Tech.(Information Security)
MNNIT Allahabad
Ph. No:+918303325388
