- To:
- Subject: Re: [cgal-discuss] mesh of small labelled subdomain
- Date: Thu, 15 Dec 2011 18:05:22 +0100
another way to remedy the problem of missing small components
is to scan the image in a pretreatment,
identifying the connected components of each label and
generating at least one initial point in each.
Le 14/12/11 08:16, Sebastien Loriot (GeometryFactory) a écrit :
My guess is that you need to adapt the mesh criteria to the size of your subdomain.
Sebastien.
rychet wrote:
I have problem with meshing of small subdomains in the segmented image.
If the subdomain is small (e.g. cube of 40x40x40 voxels) it does not appear in the final mesh. Can it be somehow controlled? Thank you
Ivan Rychetsky.
Ivan Rychetsky
Institute of Physics
Prague
View this message in context: http://cgal-discuss.949826.n4.nabble.com/mesh-of-small-labelled-subdomain-tp4182320p4182320.html
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- [cgal-discuss] mesh of small labelled subdomain, rychet, 12/11/2011
- Re: [cgal-discuss] mesh of small labelled subdomain, Sebastien Loriot (GeometryFactory), 12/14/2011
- Re: [cgal-discuss] mesh of small labelled subdomain, Mariette Yvinec, 12/15/2011
- [cgal-discuss] Re: mesh of small labelled subdomain, rychet, 12/17/2011
