cgal-discuss - [cgal-discuss] Re: VC compiler issue: static filter in cgal 3.8
  • To:
  • Subject: [cgal-discuss] Re: VC compiler issue: static filter in cgal 3.8
  • Date: Fri, 16 Dec 2011 02:21:40 -0800 (PST)
Laurent Rineau (GeometryFactory) wrote
> Our test machine got upgraded to VC2010sp1 too (it was a security update).
> Tonight the nighly testsuite of CGAL will be using the CGAL-3.8 branch,
> and
> tomorrow I will be able to tell you if we reproduced your issue.
Hello,
I am getting the same error while compiling my code using /O2 option:
c:\users\hamid\local\cgal\3.8-vc10-w64\include\cgal\internal\static_filters\power_test_3.h(178):
fatal error C1001: An internal error has occurred in the compiler.
2> (compiler file
'f:\dd\vctools\compiler\utc\src\p2\main.c[0x5C45B0D8:0x00000028]', line 183)
Have you guys been able to reproduce this?
thanks,
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/VC-compiler-issue-static-filter-in-cgal-3-8-tp3465534p4203993.html
