- To:
- Subject: Re: [cgal-discuss] Re: Surface_reconstruction_points_3 problem
- Date: Wed, 28 Dec 2011 08:51:13 +0100
Sorry I answered too fast.
It is there:
CGAL-ROOT/examples/Surface_reconstruction_points_3/data
where CGAL-ROOT is where the CGAL directory has been installed.
Sebastien.
mysmax wrote:
Thank you for your answer but the result is as below
C:\Users\ASHOK PATIL\Desktop\cgalBuild\exampleBuild\examples\Sur
The system cannot find the path specified.
there is no such thing in Surface_reconstruction_points_3 folder will you
give this data to me.
thanks and regards
mysmax
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Surface-reconstruction-points-3-problem-tp4236933p4238979.html
- [cgal-discuss] Surface_reconstruction_points_3 problem, mysmax, 12/27/2011
- Re: [cgal-discuss] Surface_reconstruction_points_3 problem, Sebastien Loriot (GeometryFactory), 12/27/2011
- [cgal-discuss] Re: Surface_reconstruction_points_3 problem, mysmax, 12/28/2011
- Re: [cgal-discuss] Re: Surface_reconstruction_points_3 problem, Sebastien Loriot (GeometryFactory), 12/28/2011
- [cgal-discuss] Re: Surface_reconstruction_points_3 problem, mysmax, 12/29/2011
- Re: [cgal-discuss] Re: Surface_reconstruction_points_3 problem, Sebastien Loriot (GeometryFactory), 12/30/2011
