- To:
- Subject: Re: [cgal-discuss] Re: Surface_reconstruction_points_3 problem
- Date: Fri, 30 Dec 2011 08:04:42 +0100
The off generated file can be open with the Polyhedron_3 demo for
example or with other classical tool like MeshLab.
see this page
http://people.sc.fsu.edu/~jburkardt/data/off/off.html
for a description of the file format.
Sebastien.
mysmax wrote:
Thank you very for data file. Does the output for
poisson_reconstruction_example.cpp as below
Creates Poisson triangulation...
creates poisson triangulation: 3.62 seconds, 5 Mb allocted
Delaunay refinement...
. creates queue
creates matrix
solve poisson equation
end of solve poisson equation
etc.
is this the output while run this program. regards mysmax
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Surface-reconstruction-points-3-problem-tp4236933p4241944.html
- [cgal-discuss] Surface_reconstruction_points_3 problem, mysmax, 12/27/2011
- Re: [cgal-discuss] Surface_reconstruction_points_3 problem, Sebastien Loriot (GeometryFactory), 12/27/2011
- [cgal-discuss] Re: Surface_reconstruction_points_3 problem, mysmax, 12/28/2011
- Re: [cgal-discuss] Re: Surface_reconstruction_points_3 problem, Sebastien Loriot (GeometryFactory), 12/28/2011
- [cgal-discuss] Re: Surface_reconstruction_points_3 problem, mysmax, 12/29/2011
- Re: [cgal-discuss] Re: Surface_reconstruction_points_3 problem, Sebastien Loriot (GeometryFactory), 12/30/2011
