- To:
- Subject: [cgal-discuss] MeshDomain_3 as a class member
- Date: Fri, 30 Dec 2011 10:58:02 -0800 (PST)
I have a class in which I am trying to create and optimize/exude a
tetrahedral mesh.
Mesh generation and optimization are going to happen in two different class
member methods.
My question is how to share MeshDomain_3 between the methods so I can call
make_mesh_3 and odt_optimize_mesh_3 separately.
I did try making 'domain' a class member but then when I want to create the
mesh using following code, I get errors:
class A
MeshDomain_3 domain;
CGAL::Image_3 image;
C3t3 c3t3;
createMesh();
optimizeMesh();
A::createMesh()
image.read(filename);
domain = MeshDomain_3(image);
c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
B::optimizeMesh()
CGAL::odt_optimize_mesh_3(c3t3, domain);
All typedefs are based on example from examples/Mesh_3/mesh_3D_image.cpp
thanks in advance
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/MeshDomain-3-as-a-class-member-tp4246498p4246498.html
- [cgal-discuss] MeshDomain_3 as a class member, Hamid G, 12/30/2011
