- To:
- Cc: Winnie Hellmann <>
- Subject: Re: [cgal-discuss] Vertical ray shoot in triangulation
- Date: Fri, 06 Jan 2012 17:18:17 +0100
Le vendredi 06 janvier 2012 14:02:26 Winnie Hellmann a écrit :
> Dear list,
> I am trying to find all vertices and edges of a triangulation
> (Constrained_Delaunay_triangulation_2) that intersect with an vertical
> upward ray with given x-coordinate. My first approach was to use the
> Triangulation_line_face_circulator_2, which fails in case the ray is
> collinear to a vertical edge on the left side of the triangulation's
> convex hull (see [1] and [2], and alo l2 in [3]).
In the case of l2 in [3], you could reverse the ray direction, to be in the
case l4, and use the circulator backward.
> [1] http://www.winniehell.de/tmp/cgal/input.svg
> [2] http://www.winniehell.de/tmp/cgal/triangulation.svg
> [3]
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/C
> lass_Triangulation_2.html#Triangulation_ref_Fig_Line_face_circulator
Laurent Rineau, PhD
- [cgal-discuss] Vertical ray shoot in triangulation, Winnie Hellmann, 01/06/2012
- Re: [cgal-discuss] Vertical ray shoot in triangulation, Laurent Rineau (GeometryFactory), 01/06/2012
- Re: [cgal-discuss] Vertical ray shoot in triangulation, Winnie Hellmann, 01/06/2012
