cgal-discuss - Re: [cgal-discuss] Volunteers for upcoming projects
  • To:
  • Subject: Re: [cgal-discuss] Volunteers for upcoming projects
  • Date: Mon, 9 Jan 2012 05:19:03 +0530
Hii,
 I am currently in need of two routines. I am working on building a "Robot Localization Visualizer" using Qt and CGAL.
I have never used Qt, could someone also direct me to a resource of using Qt with CGAL. I need to make elementary polygons.
  1.  Calculating visibility polygon of a point inside a polygon
  2.  Calculating visibility polygon of a line.
Kindly direct me to a suitable resource.
thanks and regards,
Apurv Verma
B. Tech.(CSE)
IIT- Ropar
On Fri, Oct 28, 2011 at 5:12 PM, zeinab hasani <> wrote:
hi
I slove visibilty polygon of a point inside a polygon.
what can I help you?
>> I appreciate that. did you (winnie.hellmann) implement this project:
>> "calculating visibility polygon of a point inside a polygon"?
> I am not sure about what kind of project you are talking. But the
> implementation I am currently working on solves the problem of
> calculating visibility polygons for points inside a polygon. Actually it
> is even less restrictive and can calculate visibility polygons of points
> in any arrangement without isolated vertices (not only polygons and
> query points do not have to lie inside).
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
