- To:
- Subject: Re: [cgal-discuss] poisson_reconstruction_example can't get result
- Date: Mon, 9 Jan 2012 01:11:11 -0500 (EST)
thank you for your reply Saboret, my taucs was downloaded from the official website,
by the way i use vs2005 native, there are a lot of link errors so i re-compile some taucs-depend-libs under vs2005 such as vcf2c.lib,
do what are the differences between the official and cgal-modified taucs? are there any public documents?
thank you again.
thank you again.
-----Original Message-----
To: cgal-discuss <>
Sent: Fri, Jan 6, 2012 6:14 pm
To: cgal-discuss <>
Hi,
My guess is that TAUCS is not properly installed on your machine.
On Windows, you should use CGAL installer to download and install TAUCS.
On Unix, you should download TAUCS from https://gforge.inria.fr/frs/download.php/24628/taucs_full.tgz,
then uncompress it and run the installer.
Best regards,
Laurent Saboret
Le 06/01/2012 10:58, cetium a écrit :
> i run this example with the defaut option but it shows "cant's solve Poisson
> equation",taucs log outputs "Incorrect Matrix"
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/poisson-reconstruction-example-can-t-get-result-tp4268821p4268821.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
- [cgal-discuss] poisson_reconstruction_example can't get result, cetium, 01/06/2012
- Re: [cgal-discuss] poisson_reconstruction_example can't get result, Laurent Saboret, 01/06/2012
- Re: [cgal-discuss] poisson_reconstruction_example can't get result, Dr. W, 01/09/2012
- Re: [cgal-discuss] poisson_reconstruction_example can't get result, Laurent Saboret, 01/09/2012
