- To:
- Subject: [cgal-discuss] 3D boolean operation - result gets deleted
- Date: Fri, 13 Jan 2012 01:12:40 -0800 (PST)
Hello,
I'm new to CGAL and I'm trying to use the 3D boolean operation on
Nef_polyhedron_3.
I was able to construct two objects (surface1 and surface2) by reading
off-files and converting the polyhedron to Nef_polyhedron_3:
Nef_polyhedron_3 surface1;
Nef_polyhedron_3 surface2;
Then I substract both surfaces and the result is in result_surface:
Nef_polyhedron_3 result_surface = surface1 - surface2;
Now I want to return the result_surface in my function to be able to use it
in another function. However, since result_surface is no pointer, it gets
deleted at the moment that I leave my function. Is there a way to return
this without it being deleted? I was thinking of returning a copy of
result_surface, but I couldn't find a copy constructor for Nef_polyhedron_3.
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-boolean-operation-result-gets-deleted-tp4291727p4291727.html
- [cgal-discuss] 3D boolean operation - result gets deleted, Veerle, 01/13/2012
- Re: [cgal-discuss] 3D boolean operation - result gets deleted, Andreas Fabri, 01/13/2012
