cgal-discuss - Re: [cgal-discuss] 3D boolean operation - result gets deleted
  • To:
  • Subject: Re: [cgal-discuss] 3D boolean operation - result gets deleted
  • Date: Fri, 13 Jan 2012 10:49:31 +0100
On 13/01/2012 10:12, Veerle wrote:
Hello,
I'm new to CGAL and I'm trying to use the 3D boolean operation on
Nef_polyhedron_3.
I was able to construct two objects (surface1 and surface2) by reading
off-files and converting the polyhedron to Nef_polyhedron_3:
Nef_polyhedron_3 surface1;
Nef_polyhedron_3 surface2;
Then I substract both surfaces and the result is in result_surface:
Nef_polyhedron_3 result_surface = surface1 - surface2;
Now I want to return the result_surface in my function to be able to use it
in another function. However, since result_surface is no pointer, it gets
deleted at the moment that I leave my function. Is there a way to return
this without it being deleted? I was thinking of returning a copy of
result_surface, but I couldn't find a copy constructor for Nef_polyhedron_3.
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-boolean-operation-result-gets-deleted-tp4291727p4291727.html
Taken that the assignment worked, just return the result from
your function and make an assignment in the calling function.
Nef_polyhedron_3 surface = myFct(surface1, surface2);
andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
