- To:
- Subject: [cgal-discuss] weighted alpha shape 2d, minimal example
- Date: Wed, 18 Jan 2012 02:34:41 -0800 (PST)
Hello,
I'm trying to get a minimal example of a weighted alpha shape to work in 2d.
However the example programs in the manual consist of only typedefs. I use
simple double precision arithmatic, so it becomes:
If I use these and try to insert RT::Weighted_point into an AS instance, I
get compiler errors saying the
The 3D version apparently has a different template structure, where points
are derived as
CGAL::Regular_triangulation_euclidean_traits_3<K>::Weighted_point;
This type is not present in the
CGAL::Weighted_alpha_shape_euclidean_traits_2<K>, there is a
typedef ... Point; present in the header-file, but it gives the same
compiler-error when used.
Does anyone have a working example file from which I can kickstart?
Many thanks,
Johan Hidding
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/weighted-alpha-shape-2d-minimal-example-tp4306254p4306254.html
- [cgal-discuss] weighted alpha shape 2d, minimal example, hidding, 01/18/2012
- [cgal-discuss] Re: weighted alpha shape 2d, minimal example, hidding, 01/18/2012
- Re: [cgal-discuss] Re: weighted alpha shape 2d, minimal example, Sebastien Loriot (GeometryFactory), 01/18/2012
