- To:
- Subject: Re: [cgal-discuss] Re: weighted alpha shape 2d, minimal example
- Date: Wed, 18 Jan 2012 11:52:28 +0100
On 01/18/2012 11:43 AM, hidding wrote:
Apparently the mail-system removes the "raw" tags, here's the typedefs:CGAL's source is coming with an example
typedef CGAL::Cartesian<double> K;
typedef CGAL::Weighted_alpha_shape_euclidean_traits_2<K> Gt;
typedef CGAL::Alpha_shape_vertex_base_2<Gt> Av;
typedef CGAL::Regular_triangulation_face_base_2<Gt> Rf;
typedef CGAL::Alpha_shape_face_base_2<Gt,Rf> Af;
typedef CGAL::Triangulation_default_data_structure_2<Gt,Av,Af> Tds;
typedef CGAL::Regular_triangulation_2<Gt,Tds> Rt;
typedef CGAL::Alpha_shape_2<Rt> AS;
and the given compiler error (gcc-4.6, CGAL-3.8):
CGAL::Alpha_shape_vertex_base_2<yada yada ...> has no member named
'is_hidden' / 'set_hidden'.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/weighted-alpha-shape-2d-minimal-example-tp4306254p4306270.html
examples/Alpha_shapes_2/ex_weighted_alpha_shapes_2.cpp
WARNING: you also need the file data/fin
Sebastien.
/*********************************************************************** Takes a list of points and returns a list of segments corresponding to the weighted Alpha Shape. ************************************************************************/ #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Weighted_point.h> #include <CGAL/Weighted_alpha_shape_euclidean_traits_2.h> #include <CGAL/Regular_triangulation_2.h> #include <CGAL/Alpha_shape_2.h> #include <iostream> #include <fstream> #include <vector> #include <list> typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef K::FT FT; typedef K::Point_2 Point_base; typedef CGAL::Weighted_point<Point_base,FT> Point; typedef K::Segment_2 Segment; typedef CGAL::Weighted_alpha_shape_euclidean_traits_2<K> Gt; typedef CGAL::Regular_triangulation_vertex_base_2<Gt> Rvb; typedef CGAL::Alpha_shape_vertex_base_2<Gt,Rvb> Vb; typedef CGAL::Regular_triangulation_face_base_2<Gt> Rf; typedef CGAL::Alpha_shape_face_base_2<Gt, Rf> Fb; typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds; typedef CGAL::Regular_triangulation_2<Gt,Tds> Triangulation_2; typedef CGAL::Alpha_shape_2<Triangulation_2> Alpha_shape_2; typedef Alpha_shape_2::Face Face; typedef Alpha_shape_2::Vertex Vertex; typedef Alpha_shape_2::Edge Edge; typedef Alpha_shape_2::Face_handle Face_handle; typedef Alpha_shape_2::Vertex_handle Vertex_handle; typedef Alpha_shape_2::Face_circulator Face_circulator; typedef Alpha_shape_2::Vertex_circulator Vertex_circulator; typedef Alpha_shape_2::Locate_type Locate_type; typedef Alpha_shape_2::Face_iterator Face_iterator; typedef Alpha_shape_2::Vertex_iterator Vertex_iterator; typedef Alpha_shape_2::Edge_iterator Edge_iterator; typedef Alpha_shape_2::Edge_circulator Edge_circulator; typedef Alpha_shape_2::Alpha_iterator Alpha_iterator; typedef Alpha_shape_2::Alpha_shape_edges_iterator Alpha_shape_edges_iterator; //--------------------------------------------------------------------- template <class InputIterator, class OutputIterator> void alpha_edges(InputIterator begin, InputIterator end, const FT &Alpha, bool mode, OutputIterator out) // Generate Alpha Shape { std::vector<Gt::Segment_2> V_seg; Alpha_shape_2 A(begin,end); if (mode) { A.set_mode(Alpha_shape_2::GENERAL); } else { A.set_mode(Alpha_shape_2::REGULARIZED); }; A.set_alpha(Alpha); for(Alpha_shape_edges_iterator it = A.alpha_shape_edges_begin(); it != A.alpha_shape_edges_end(); ++it){ *out++ = A.segment(*it); } } //--------------------------------------------------------------------- bool file_input(std::list<Point>& L) { std::ifstream is("./data/fin", std::ios::in); if(is.fail()) { std::cerr << "unable to open file for input" << std::endl; return false; } CGAL::set_ascii_mode(is); int n; is >> n; std::cout << "Reading " << n << " points" << std::endl; Point_base p; for( ; n>0 ; n--) { is >> p; L.push_back(Point (p, FT(10))); } std::cout << "Points inserted" << std::endl; return true; } //------------------ main ------------------------------------------- int main() { std::list<Point> points; file_input(points); std::vector<Gt::Segment_2> segments; alpha_edges(points.begin(), points.end(), FT(10000),Alpha_shape_2::GENERAL, std::back_inserter(segments)); std::cout << segments.size() << " alpha shape edges." << std::endl; return 0; }
- [cgal-discuss] weighted alpha shape 2d, minimal example, hidding, 01/18/2012
- [cgal-discuss] Re: weighted alpha shape 2d, minimal example, hidding, 01/18/2012
- Re: [cgal-discuss] Re: weighted alpha shape 2d, minimal example, Sebastien Loriot (GeometryFactory), 01/18/2012
