cgal-discuss - Re: [cgal-discuss] partitionning Polygon_2 with holes
  • To:
  • Subject: Re: [cgal-discuss] partitionning Polygon_2 with holes
  • Date: Wed, 18 Jan 2012 11:43:50 +0100
On 01/18/2012 11:09 AM, Thomas Recouvreux wrote:
Hi,
Thanks for the answer.
If I have well understand the delaunay triangulation there are a big
problem : some edges will be constructed inside the holes.
Which is not a problem as you can simply do not consider these triangles. See this thread for example (the code works for non intersecting polygons but can simply be extended).
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2011-11/msg00150.html
Secondly the decomposition is not optimal. I saw on this link
http://forums.create.msdn.com/forums/t/50204.aspx someone speaks about
CGAL, he merges polygons to have complex polygon with holes (binary
difference operation I think) then he uses mp5 algorithm to make an
optimal partition, the result is exactly what I would like to get (a
navigation graph). Do you know what mp5 algorithm refers to ?
No idea but a link is provided to a paper on the page you refer to.
I guess it's a union of adjacent triangles to form maximal convex set.
Sebastien.
2012/1/18 Sebastien Loriot (GeometryFactory)
<mailto:>>
The input polygon should be simple and without holes.
In you case you might want to try to use a constrained (Delaunay)
triangulation (edges of your polygon are constraints).
The decomposition would be minimal at all but it will be convex.
See:
http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2/Chapter_main.__html#Section_36.7
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_36.7>
Sebastien.
Hi,
I've have found some examples about partitionning a Polygon_2,
but I didn't see functions for partitionning a Poly_2 with
holes. Is there any function to do so or shall I decompose first
my polygon with holes in polygons without holes and apply the
partitionning function ?
An other question, I tried to use partition function on a
polygon with tangente edges (see below), and the function return
the whole polygon without partionning it, did I miss something ?
+-----------------------------__----------+
polygon.push_back(Point_2(0, 0));
polygon.push_back(Point_2(10, 0));
polygon.push_back(Point_2(6, 2));
polygon.push_back(Point_2(2, 2));
polygon.push_back(Point_2(2, 6));
polygon.push_back(Point_2(6, 6));
polygon.push_back(Point_2(10, 10));
polygon.push_back(Point_2(0,__10));
Best
Thomas
https://lists-sop.inria.fr/__wws/info/cgal-discuss
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
