- To:
- Subject: Re: [cgal-discuss] partitionning Polygon_2 with holes
- Date: Wed, 18 Jan 2012 09:27:26 +0100
The input polygon should be simple and without holes.
In you case you might want to try to use a constrained (Delaunay)
triangulation (edges of your polygon are constraints).
The decomposition would be minimal at all but it will be convex.
See:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_36.7
Sebastien.
Thomas Recouvreux wrote:
Hi,
I've have found some examples about partitionning a Polygon_2, but I didn't see functions for partitionning a Poly_2 with holes. Is there any function to do so or shall I decompose first my polygon with holes in polygons without holes and apply the partitionning function ?
An other question, I tried to use partition function on a polygon with tangente edges (see below), and the function return the whole polygon without partionning it, did I miss something ?
polygon.push_back(Point_2(0, 0));
polygon.push_back(Point_2(10, 0));
polygon.push_back(Point_2(6, 2));
polygon.push_back(Point_2(2, 2));
polygon.push_back(Point_2(2, 6));
polygon.push_back(Point_2(6, 6));
polygon.push_back(Point_2(10, 10));
polygon.push_back(Point_2(0,10));
Best
Thomas
- [cgal-discuss] partitionning Polygon_2 with holes, Thomas Recouvreux, 01/17/2012
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Sebastien Loriot (GeometryFactory), 01/18/2012
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Thomas Recouvreux, 01/18/2012
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Mariette Yvinec, 01/18/2012
