- To:
- Subject: Re: Re: [cgal-discuss] Coplanar Points in a 3D Triangulation
- Date: Thu, 19 Jan 2012 16:13:26 +0100
Hi Sebastien and Laurent:
Please, see these links below with my code and the input file of 3D points:
When I run my code, the test (if (CGAL::orientation(p1, p2, p3, p4) == CGAL::COPLANAR)) is never satisfied, but when I compute the Jacobian is equal to 0.000000000000, is to say, that the 4 points of several thetraedra are coplanar. Maybe Laurent have reason, but How can I solve this problem? Could you give me suggestions?
Thank you for all and waiting your answer
Juan Carlos
On Thu, Jan 19, 2012 at 3:41 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le jeudi 19 janvier 2012 15:12:16 Juan Carlos Lopez Alfonso a écrit :
> Hi Sebastien:That way of detecting coplanarity is subject to rounding errors. Probably you
> To detect that points are coplanar, I have computed the jacobian of each
> thetraedra:
> //for each thetraedra !!!
> Tetrahedron t = T[i];
> Vertex p1 = cit->vertex(0);
> Vertex p2 = cit->vertex(1);
> Vertex p3 = cit->vertex(2);
> Vertex p4 = cit->vertex(3);
> double Jacobian =
> (p2.x - p1.x) * (p3.y - p1.y) * (p4.z - p1.z) + (p3.x - p1.x) * (p4.y -
> p1.y) * (p2.z - p1.z) + (p4.x - p1.x) * (p2.y - p1.y) * (p3.z - p1.z)
> - (p4.x - p1.x) * (p3.y - p1.y) * (p2.z - p1.z) - (p3.x - p1.x) * (p2.y -
> p1.y) * (p4.z - p1.z) - (p2.x - p1.x) * (p4.y - p1.y) * (p3.z - p1.z);
have almost-coplanar points in your data set, but in reality, using a
certified arithmetic, there are not coplanar.
Laurent Rineau, PhD
- [cgal-discuss] Coplanar Points in a 3D Triangulation, Juan Carlos Lopez Alfonso, 01/19/2012
- Re: [cgal-discuss] Coplanar Points in a 3D Triangulation, Sebastien Loriot (GeometryFactory), 01/19/2012
- Re: [cgal-discuss] Coplanar Points in a 3D Triangulation, Juan Carlos Lopez Alfonso, 01/19/2012
- Re: Re: [cgal-discuss] Coplanar Points in a 3D Triangulation, Laurent Rineau (GeometryFactory), 01/19/2012
- Re: Re: [cgal-discuss] Coplanar Points in a 3D Triangulation, Juan Carlos Lopez Alfonso, 01/19/2012
- Re: [cgal-discuss] Coplanar Points in a 3D Triangulation, Juan Carlos Lopez Alfonso, 01/20/2012
- Re: [cgal-discuss] Coplanar Points in a 3D Triangulation, Sebastien Loriot (GeometryFactory), 01/20/2012
