cgal-discuss - [cgal-discuss] Coplanar Points in a 3D Triangulation
  • To:
  • Subject: [cgal-discuss] Coplanar Points in a 3D Triangulation
  • Date: Thu, 19 Jan 2012 15:01:06 +0100
Hi there:
I have a problem with a 3D triangulation. I have the following code:
#include <CGAL/Delaunay_triangulation_3.h>
typedef CGAL::Delaunay_triangulation_3<K, Tds>  Delaunay;
typedef Delaunay::Cell_handle    Cell_handle;
typedef Delaunay::Vertex_handle  Vertex_handle;
typedef Delaunay::Locate_type    Locate_type;
typedef Delaunay::Point          Point;
typedef Delaunay::size_type      size_type;
typedef Delaunay::Finite_vertices_iterator  Finite_vertices_iterator;
typedef Delaunay::Finite_cells_iterator Finite_cells_iterator;
Delaunay T;
T.insert(L.begin(), L.end());
for(Finite_cells_iterator cit = T.finite_cells_begin(), end = T.finite_cells_end(); cit != end; ++cit)
     ... coplanar points ...
where L is a list of 3D points. When I run my code, I have detected that there are several tetrahedra which its 4 points are coplanar.
Could anyone help me to solve this problem? I need a triangulation where all tetrahedra has no its 4 points in the same plane.
Thank you in advance and waiting for a suggestion
Juan Carlos
