RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
- To: <>
- Subject: RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
- Date: Tue, 24 Jan 2012 15:53:04 +1200
- Importance: Normal
Dear Dr. Loriot,
Thank you very much for your kindly reply. I am trying to study the example 'polyhedron_prog_incr_builder' and tried to modify the file 'polyhedron_prog_incr_builder.cpp' as follows: /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// #include <CGAL/Simple_cartesian.h> #include <CGAL/Polyhedron_incremental_builder_3.h> #include <CGAL/Polyhedron_3.h> // A modifier creating a triangle with the incremental builder. template <class HDS> class Build_triangle : public CGAL::Modifier_base<HDS> { public: Build_triangle(int nVertices, double *Vertices, int nTri, int *Tri) {} void operator()( HDS& hds) { // Postcondition: `hds' is a valid polyhedral surface. CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true); B.begin_surface( 3, 1, 6); typedef typename HDS::Vertex Vertex; typedef typename Vertex::Point Point; double *v=Vertices; for (int i=0;i<nVertices;i++) B.add_vertex( Point( *v++, *v++, *v++)); for (int i=0;i<nTri;i++) { B.begin_facet(); B.add_vertex_to_facet( *Tri++); B.add_vertex_to_facet( *Tri++); B.add_vertex_to_facet( *Tri++); B.end_facet(); } B.end_surface(); } }; typedef CGAL::Simple_cartesian<double> Kernel; typedef CGAL::Polyhedron_3<Kernel> Polyhedron; typedef Polyhedron::HalfedgeDS HalfedgeDS; int main() { Polyhedron P; int nVertices=3; double Vertices[]={0, 0, 0,1, 0, 0,0, 1, 0}; int nTri=1; int Tri[]={0,1,2}; Build_triangle<HalfedgeDS> triangle(nVertices,Vertices,nTri,Tri); P.delegate( triangle); //CGAL_assertion( P.is_triangle( P.halfedges_begin())); return 0; } /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// The following errors displayed: 1>------ Build started: Project: polyhedron_prog_incr_builder, Configuration: Debug Win32 ------ 1>Build started 2012/1/24 11:50:26. 1>InitializeBuildStatus: 1> Touching "polyhedron_prog_incr_builder.dir\Debug\polyhedron_prog_incr_builder.unsuccessfulbuild". 1>CustomBuild: 1> All outputs are up-to-date. 1>ClCompile: 1> polyhedron_prog_incr_builder.cpp 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(16): error C2065: 'Vertices' : undeclared identifier 1> D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(10) : while compiling class template member function 'void Build_triangle<HDS>::operator ()(HDS &)' 1> with 1> [ 1> HDS=HalfedgeDS 1> ] 1> D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(41) : see reference to class template instantiation 'Build_triangle<HDS>' being compiled 1> with 1> [ 1> HDS=HalfedgeDS 1> ] 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(17): error C2065: 'nVertices' : undeclared identifier 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(19): error C2065: 'nTri' : undeclared identifier 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(22): error C2065: 'Tri' : undeclared identifier 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(23): error C2065: 'Tri' : undeclared identifier 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(24): error C2065: 'Tri' : undeclared identifier 1> 1>Build FAILED. 1> 1>Time Elapsed 00:00:02.53 ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ========== Could you please help me to check the problem? Thanks > Date: Wed, 18 Jan 2012 11:55:11 +0100 > From: > To: > Subject: Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL? > > CGAL cannot handle directly cylinders but only discrete polyhedral models. > > See the documentation of Nef package for more details: > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html > > Sebastien. > > On 01/18/2012 10:41 AM, Zhanghong Tang wrote: > > Dear Dr. Loriot, > > > > Thank you very much for your kindly reply. > > > > My requirement is as follows: > > 1) read the geometries to do the operations; > > for example, two cylinders with both radius 1 and length 10, the center > > of top and bottom facet of two cylinders are: > > cylinder 1: > > top facet: (0,0,5) > > bottom facet: (0,0,-5) > > cylinder 2: > > top facet (5,0,0) > > bottom facet: (-5,0,0) > > > > 2) find the 3D Boolean operations of input objects and output the > > presentation by OFF file format. > > for example, find the unite of two crossed cylinders and output the > > presentation by OFF file format. > > > > > > How to implement this with mimimal code? > > > > > > Thanks, > > Zhanghong Tang > > > > > > P.S.: > > I notice that the mesher 'NetGen' takes the CSG format as its input > > file, however, it can't handle the simplest example (it works when the > > radius of two cylinders are not equal), I guess that the CGAL can handle > > it easily. > > > > > > > > > Date: Wed, 18 Jan 2012 08:25:30 +0100 > > > From: > > > To: > > > Subject: Re: [cgal-discuss] What's the minimal requirement to use the > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > Zhanghong Tang wrote: > > > > Dear all, > > > > > > > > I would like use the CSG module of CGAL, what's the minimal > > requirement > > > > to use this module? I want to build it to a blockbox with CSG module > > > > data input and another format data output (for example, piecewise > > linear > > > > complex format, Geomview's polyhedral file format (OFF)), which files > > > > should I select to compile and is there any interface to use this > > module? > > > > > > > > Thanks, > > > > Zhanghong Tang > > > > > > > Your question is not clear to me. Could you explain what you are looking > > > for exactly? > > &g t; > > > For 3D Boolean operations, you need to use Nef_3: > > > > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html > > > For simple polyhedron manipulation, you can use Polyhedron_3: > > > > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html > > > > > > Sebastien. > > > > > > -- > > > You are currently subscribed to cgal-discuss. > > > To unsubscribe or access the archives, go to > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss > |
- [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/12/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/18/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/18/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/24/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Guillaume Damiand, 01/24/2012
- Message not available
- FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/25/2012
- Re: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Winnie Hellmann, 01/25/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/25/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/25/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/27/2012
