Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
- To:
- Subject: Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
- Date: Wed, 18 Jan 2012 08:25:30 +0100
Zhanghong Tang wrote:
> Dear all,
> I would like use the CSG module of CGAL, what's the minimal requirement
> to use this module? I want to build it to a blockbox with CSG module
> data input and another format data output (for example, piecewise linear
> complex format, Geomview's polyhedral file format (OFF)), which files
> should I select to compile and is there any interface to use this module?
> Thanks,
> Zhanghong Tang
Your question is not clear to me. Could you explain what you are looking
for exactly?
For 3D Boolean operations, you need to use Nef_3:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html
For simple polyhedron manipulation, you can use Polyhedron_3:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html
Sebastien.
- [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/12/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/18/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/18/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/24/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Guillaume Damiand, 01/24/2012
- Message not available
- FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/25/2012
- Re: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Winnie Hellmann, 01/25/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/25/2012
