- To:
- Subject: [cgal-discuss] Re: Create Delaunay 3D
- Date: Wed, 25 Jan 2012 08:23:53 -0800 (PST)
First of all thank you for your replay.
I actually include all needed files.
I include the hole boost directory and the lib directory (how I saw it in
different examples).
When I build the convex_hull3 example it will work almost fine but only when
I will use this example in my application there is an error. But the
configuration is nearly the same :/
Can I link the file hardly or something like that?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Create-Delaunay-3D-tp4317918p4327672.html
- [cgal-discuss] Create Delaunay 3D, Gropi, 01/22/2012
- Re: [cgal-discuss] Create Delaunay 3D, Sebastien Loriot (GeometryFactory), 01/23/2012
- [cgal-discuss] Re: Create Delaunay 3D, Gropi, 01/25/2012
- Re: [cgal-discuss] Re: Create Delaunay 3D, Sebastien Loriot (GeometryFactory), 01/25/2012
