cgal-discuss - Re: [cgal-discuss] Re: Create Delaunay 3D
  • To:
  • Subject: Re: [cgal-discuss] Re: Create Delaunay 3D
  • Date: Wed, 25 Jan 2012 17:43:24 +0100
On 01/25/2012 05:23 PM, Gropi wrote:
First of all thank you for your replay.
I actually include all needed files.
I include the hole boost directory and the lib directory (how I saw it in
different examples).
It's not a matter of include paths, you need to link with boost_thread. For example, with gcc you need to add -lboost_thread
Sebastien.
When I build the convex_hull3 example it will work almost fine but only when
I will use this example in my application there is an error. But the
configuration is nearly the same :/
Can I link the file hardly or something like that?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Create-Delaunay-3D-tp4317918p4327672.html
