- To:
- Subject: Re: [cgal-discuss] Converting doubles to Filtered_extended_homogeneous
- Date: Fri, 27 Jan 2012 00:34:42 +0100
> Does CGAL offer a way to intelligently convert doubles to a ring type?
I would say, that depends on the ring type you use. Did you just try
assigning it? For example CGAL::Gmpq automatically casts double values.
Best regards,
Winnie Hellmann
PGP key: http://www.winniehell.de/0xA8FE4F09.pub.asc
signature.asc
Description: OpenPGP digital signature
- [cgal-discuss] Converting doubles to Filtered_extended_homogeneous, erickee, 01/27/2012
- Re: [cgal-discuss] Converting doubles to Filtered_extended_homogeneous, Winnie Hellmann, 01/27/2012
- [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous, erickee, 01/27/2012
