FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
- To: <>
- Subject: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
- Date: Mon, 30 Jan 2012 12:04:16 +1200
- Importance: Normal
Dear all,
Could anyone help me to check my problem? I use the 3-D geometry boolean operation of CGAL to substract a slot (test2.off) from a cylinder (test1.off), the result geometry represented by test3.off seems to be not valid for mesh generation. There are many duplicated vertices and degenerated facets (facets with area zero). Is there any method to avoid that, or is there any check program to correct the outputted OFF file? Thanks From: To: Date: Mon, 30 Jan 2012 03:04:13 +1200 Subject: RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
Dear Sebastien, Thank you very much for point out this for me. Now it works. I have another question: I have one cylinder (test1.off) and a slot (test2.off) be substracted from the cylinder, the result is test3.off. However, I checked the vertices of test3.off and found that many vertices are duplicated. For example: 0.06, 0, -0.15 0.06, -2.63531e-017, -0.15 and 0.06, -2.63531e-017, -0.45 0.06, 2.63531e-017, -0.45 Furthermore, there are many facets look like a line, for example: (24, 0, 54) I guess it is because of the 'exact construction' so the code still takes (0.06, 0, -0.15) and (0.06, -2.63531e-017, -0.15) as different vertices. Can I set anything in the code to set a 'inexact' threshold and let the code combine the duplicated vertices and remove degenerated facets? Thanks > Date: Fri, 27 Jan 2012 08:10:09 +0100 > From: > To: > Subject: Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL? > > > (double)vp.x(); is a C-style cast to double and I don't know what is > the result. > The correct code is CGAL::to_double(vp.x()). > > Sebastien. > > On 01/27/2012 07:54 AM, Zhanghong Tang wrote: > > Dear all, > > > > I modified code like this, this time it can run, but got error data, for > > example, 1.2334234e-300, however, I can output P to OFF file correctly. > > could anyone help me to take a look at it? > > > > Thanks > > > > > > PS: the modified code: > > > > Polyhedron *P=(Polyhedron *)object->obj; > > Point_3 vp; > > j=0; > > for ( Vertex_iterator v = P->vertices_begin(); v != P->vertices_end(); ++v) > > { > > vp=(Point_3&)v->point(); > > doublearray[j++]=(double)vp.x(); > > doublearray[j++]=(double)vp.y(); > > doublearray[j++]=(double)vp.z(); > > } > > > > > > ------------------------------------------------------------------------ > > From: > > To: > > Date: Fri, 27 Jan 2012 17:23:40 +1200 > > Subject: RE: [cgal-discuss] What's the minimal requirement to use the > > Constructive Solid Geometry (CSG) module of CGAL? > > > > Hi Sebastien, > > > > Thank you very much for point out this problem for me. Now the problem > > is solved. However, it is very slow to do union operation when there are > > many similar objects like this. Is there any more efficient method to do > > union operation by using CGAL? > > > > In addition, how to output the coordinates of vertices to an array? The > > following code seems to be wrong, how to modify the code? > > > > > > Thanks > > > > > > > > PS: the code to output coordinates of vertices to array > > > > Polyhedron P=*(Polyhedron *)object->obj; > > ... > > j=0; > > for ( Vertex_iterator v = P.vertices_begin(); v != P.vertices_end(); ++v) > > { > > doublearray[j++]=v->point()->x; > > doublearray[j++]=v->point()->y; > > doublearray[j++]=v->point()->z; > > } > > > > > > > > > > > > > > > > > Date: Wed, 25 Jan 2012 08:53:32 +0100 > > > From: > > > To: > > > Subject: Re: [cgal-discuss] What's the minimal requirement to use the > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > When you provide a face to nef polyhedron, it assumes that the points of > > > the face lies exactly on a plane. In you example, you have quad-faces > > > with non coplanar vertices. > > > To solve this issue, you can for example triangulate the faces of each > > > of your models (see attachement). > > > > > > Sebastien. > > > > > > > > > > > > > > > On 01/25/2012 06:26 AM, Zhanghong Tang wrote: > > > > Dear all, > > > > > > > > With the following code, I'd like to add multiple objects into one and > > > > then output the union to an OFF file, however, the code crashed in > > the line > > > > Nef_polyhedron nef_obj(obj); > > > > > > > > how to modify the code to let it works? I will be very appericate if > > > > anyone help me to check the code. > > > > > > > > Thanks > > > > > > > > > > > > PS: the code > > > > > > > > typedef struct object > > > > { > > > > void *obj; > > > > }myobj; > > > > > > > > void UnionObject(myobj *object, void *unionobj, int nobject) > > > > { > > > > Polyhedron obj, UnitedObj; > > > > Nef_polyhedron nef_uni; > > > > for (int i=0;i<nobject;i++) > > > > { > > > > obj=*(Polyhedron *)object[i].obj; > > > > Nef_polyhedron nef_obj(obj); > > > > if(i==0) > > > > nef_uni = nef_obj; > > > > else > > > > nef_uni = nef_uni + nef_obj; > > > > > > > > } > > > > nef_uni.convert_to_polyhedron(UnitedObj); > > > > } > > > > > > > > There are totally 6 objects to be added, the off files generated from > > > > object[i].obj (i=0,1,2,3,4,5) are attached. > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > From: > > > > To: > > > > Date: Wed, 25 Jan 2012 15:11:04 +1200 > > > > Subject: RE: [cgal-discuss] What's the minimal requirement to use the > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > Hi Guillaume, > > > > > > > > Thank you very much for your kindly reply. Now I have the following > > code > > > > to unite many objects into one: > > > > > > > > typedef struct object > > > > { > > > > void *obj; > > > > }myobj; > > > > > > > > void UnionObject(myobj *object, void *unionobj, int nobject) > > > > { > > > > Polyhedron obj, UnitedObj; > > > > Nef_polyhedron nef_uni; > > > > for (int i=0;i<nobject;i++) > > > > { > > > > obj=*(Polyhedron *)object[i].obj; > > > > Nef_polyhedron nef_obj(obj); > > > > if(i==0) > > > > nef_uni = nef_obj; > > > > else > > > > nef_uni = nef_uni + nef_obj; > > > > > > > > } > > > > nef_uni.convert_to_polyhedron(UnitedObj); > > > > } > > > > > > > > However, the program crash in the line > > > > Nef_polyhedron nef_obj(obj); > > > > > > > > Is there any missing to do this? How to modify the code to let the > > > > multiple objects be united correctly? > > > > > > > > I checked the polyhedron obj of every object[i].obj and output them to > > > > OFF file and they are all correct (under Guillaume's help). > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > From: > > > > To: > > > > Subject: RE: [cgal-discuss] What's the minimal requirement to use the > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > Date: Wed, 25 Jan 2012 14:00:22 +1200 > > > > > > > > Hi Guillaume, > > > > > > > > Thank you very much for your kindly reply. Now I have the following > > code > > > > to unite many objects into one: > > > > > > > > typedef struct object > > > > { > > > > void *obj; > > > > }myobj; > > > > > > > > void UnionObject(myobj *object, void *unionobj, int nobject) > > > > { > > > > Polyhedron obj, UnitedObj; > > > > Nef_polyhedron nef_uni; > > > > for (int i=0;i<nobject;i++) > > > > { > > > > obj=*(Polyhedron *)object[i].obj; > > > > Nef_polyhedron nef_obj(obj); > > > > if(i==0) > > > > nef_uni = nef_obj; > > > > else > > > > nef_uni = nef_uni + nef_obj; > > > > > > > > } > > > > nef_uni.convert_to_polyhedron(UnitedObj); > > > > } > > > > > > > > However, the program crash in the line > > > > Nef_polyhedron nef_obj(obj); > > > > > > > > Is there any missing to do this? > > > > I checked the polyhedron obj of every object[i].obj and output them to > > > > OFF file and they are all correct (under Guillaume's help). > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > Date: Tue, 24 Jan 2012 10:20:05 +0100 > > > > From: > > > > To: > > > > Subject: Re: [cgal-discuss] What's the minimal requirement to use the > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > Hi, > > > > > > > > Hi Guillaume, > > > > > > > > Thank you very much for your encouragement. I don't understand the > > > > benefit to wirte like this: the very complex class, constructor, and > > > > so on. > > > > > > > > > > > > The benefit is genericity. > > > > > > > > > > > > Is it possible to write just what need to be executed, or the > > > > process of execute can be see naturaly. For example: > > > > > > > > the function: > > > > > > > > Polyhedron Build_triangle(int nVertices0, double *Vertices0, int > > > > nTri0, int *Tri0) > > > > { > > > > ... > > > > } > > > > > > > > the caller: > > > > ... > > > > Polyhedron P; > > > > P=Build_triangle(nVertices,Vertices,nTri,Tri); > > > > > > > > > > > > No this is not possible: you have to use the format required by the > > > > incremental builder class... > > > > > > > > > > > > ... > > > > > > > > By the way, the following code can output the polyhedron to OFF > > > > format to the screen (from the example 'polyhedron_prog_cut_cube.cpp'): > > > > std::cout << P; > > > > > > > > how to modify the code to let it output to a file 'filename' with > > > > the definition: > > > > char *filename; > > > > > > > > > > > > Use ofstream. Cf for example > > http://www.cplusplus.com/doc/tutorial/files/ > > > > > > > > Guillaume > > > > > > > > > > > > > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > Date: Tue, 24 Jan 2012 08:28:50 +0100 > > > > From: > > > > <mailto:> > > > > To: <mailto:> > > > > Subject: Re: [cgal-discuss] What's the minimal requirement to use > > > > the Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > > > Hi Guillaume, > > > > > > > > Thank you very much for your kindly reply. Now the problem is > > > > solved. I should modify the code like this: > > > > > > > > > > > > Perfect. > > > > > > > > > > > > class Build_triangle : public CGAL::Modifier_base<HDS> { > > > > public: > > > > int nVertices; > > > > double *Vertices; > > > > int nTri; > > > > int *Tri; > > > > Build_triangle(int nVertices0, double *Vertices0, int nTri0, int > > > > *Tri0) > > > > { > > > > nVertices=nVertices0; > > > > Vertices=Vertices0; > > > > nTri=nTri0; > > > > Tri=Tri0; > > > > } > > > > > > > > > > > > Now my question is: can I pass parameters as a more simple and > > > > understandable way, just like the 'Fortran' subroutine? > > > > > > > > > > > > What do you mean by "more simple and understandable way" ? > > > > > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > From: <mailto:> > > > > To: > > > > <mailto:> > > > > Date: Tue, 24 Jan 2012 19:02:57 +1200 > > > > Subject: RE: [cgal-discuss] What's the minimal requirement to > > > > use the Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > Hi Guillaume, > > > > > > > > Thank you very much for your kindly reply. I am new to C++ class > > > > and the complex operators and don't know how to modify the code > > > > to pass the parameters to the operator. Is there any simple way > > > > to read the input vertices and facets from other functions to > > > > form the polyhedron of CGAL? To let the CGAL do boolean > > > > operations, should I do like the example? What's the simplest > > > > way? I need to generate polyhedron from CSG and then let CGAL to > > > > do the boolean opearations and then output the results to OFF file. > > > > > > > > Thanks > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > Date: Tue, 24 Jan 2012 07:09:53 +0100 > > > > From: > > > > <mailto:> > > > > To: > > > > <mailto:> > > > > Subject: Re: [cgal-discuss] What's the minimal requirement to > > > > use the Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > The variables nVertices,Vertices,nTri,nTri are parameters of the > > > > constructor of your class. > > > > Thus they are not defined in the operator(). You need to define > > > > variables in your class in order to store them. > > > > Guillaume > > > > > > > > > > > > Dear Dr. Loriot, > > > > > > > > Thank you very much for your kindly reply. I am trying to > > > > study the example 'polyhedron_prog_incr_builder' and tried > > > > to modify the file 'polyhedron_prog_incr_builder.cpp' as > > > > follows: > > > > > > /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// > > > > > > > > #include <CGAL/Simple_cartesian.h> > > > > #include <CGAL/Polyhedron_incremental_builder_3.h> > > > > #include <CGAL/Polyhedron_3.h> > > > > > > > > // A modifier creating a triangle with the incremental builder. > > > > template <class HDS> > > > > class Build_triangle : public CGAL::Modifier_base<HDS> { > > > > public: > > > > Build_triangle(int nVertices, double *Vertices, int nTri, > > > > int *Tri) {} > > > > void operator()( HDS& hds) { > > > > // Postcondition: `hds' is a valid polyhedral surface. > > > > CGAL::Polyhedro n_incremental_builder_3<HDS> B( hds, true); > > > > B.begin_surface( 3, 1, 6); > > > > typedef typename HDS::Vertex Vertex; > > > > typedef typename Vertex::Point Point; > > > > double *v=Vertices; > > > > for (int i=0;i<nVertices;i++) > > > > B.add_vertex( Point( *v++, *v++, *v++)); > > > > for (int i=0;i<nTri;i++) > > > > { > > > > B.begin_facet(); > > > > B.add_vertex_to_facet( *Tri++); > > > > B.add_vertex_to_facet( *Tri++); > > > > B.add_vertex_to_facet( *Tri++); > > > > B.end_facet(); > > > > } > > > > B.end_surface(); > > > > } > > > > }; > > > > > > > > typedef CGAL::Simple_cartesian<double> Kernel; > > > > typedef CGAL::Polyhedron_3<Kernel> Polyhedron; > > > > typedef Polyhedron::HalfedgeDS HalfedgeDS; > > > > > > > > int main() { > > > > ; Polyhedron P; > > > > int nVertices=3; > > > > double Vertices[]={0, 0, 0,1, 0, 0,0, 1, 0}; > > > > int nTri=1; > > > > int Tri[]={0,1,2}; > > > > Build_triangle<HalfedgeDS> > > > > triangle(nVertices,Vertices,nTri,Tri); > > > > P.delegate( triangle); > > > > //CGAL_assertion( P.is_triangle( P.halfedges_begin())); > > > > return 0; > > > > } > > > > > > > > > > /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// > > > > > > > > > > > > The following errors displayed: > > > > 1>------ Build started: Project: > > > > polyhedron_prog_incr_builder, Configuration: Debug Win32 ------ > > > > 1>Build started 2012/1/24 11:50:26. > > > > 1>InitializeBuildStatus: > > > > 1> Touching > > > > "polyhedron_prog_incr_builder.dir\Debug\polyhedron_prog_incr_builder > > > > .unsuccessfulbuild". > > > > 1>CustomBuild: > > > > 1> All outputs are up-to-date. > > > > 1>ClCompile: > > > > 1> polyhedron_prog_incr_builder.cpp > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(16): > > > > error C2065: 'Vertices' : undeclared identifier > > > > 1> > > > > > > D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(10) > > > > : while compiling class template member function 'void > > > > Build_triangle<HDS>::operator ()(HDS &)' > > > > 1> with > > > > 1> [ > > > > 1> HDS=HalfedgeDS > > > > 1> ] > > > > 1> > > > > > > D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(41) > > > > : see reference to class template instantiation > > > > 'Build_triangle<HDS>' being compiled > > > > 1> with > > > > 1> [ > > > > 1> HDS=HalfedgeDS > > > > 1> ] > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(17): > > > > error C2065: 'nVertices' : undeclared identifier > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(19): > > > > error C2065: 'nTri' : undeclared identifier > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(22): > > > > error C2065: 'Tri' : undeclared identifier > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(23): > > > > error C2065: 'Tri' : undeclared identifier > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\poly > > > > hedron_prog_incr_builder.cpp(24): error C2065: 'Tri' : > > > > undeclared identifier > > > > 1> > > > > 1>Build FAILED. > > > > 1> > > > > 1>Time Elapsed 00:00:02.53 > > > > ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 > > > > skipped ========== > > > > > > > > > > > > Could you please help me to check the problem? > > > > > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > > Date: Wed, 18 Jan 2012 11:55:11 +0100 > > > > > From: <mailto:> > > > > > To: > > > > <mailto:> > > > > > Subject: Re: [cgal-discuss] What's the minimal > > > > requirement to use the Constructive Solid Geometry (CSG) > > > > module of CGAL? > > > > > > > > > > CGAL cannot handle directly cylinders but only discrete > > > > polyhedral models. > > > > > > > > > > See the documentation of Nef package for more details: > > > > > > > > > > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html > > > > > > > > > > Sebastien. > > > > > > > > > > On 01/18/2012 10:41 AM, Zhanghong Tang wrote: > > > > > > Dear Dr. Loriot, > > > > > > > > > > > > Thank you very much for your kindly reply. > > > > > > > > > > > > My requirement is as follows: > > > > > > 1) read the geometries to do the operations; > > > > > > for example, two cylinders with both radius 1 and > > > > length 10, the center > > > > > > of top and bottom facet of two cylinders are: > > > > > > cylinder 1: > > > > > > top facet: (0,0,5) > > > > > > bottom facet: (0,0,-5) > > > > > > cylinder 2: > > > > > > top facet (5,0,0) > > > > > > bottom facet: (-5,0,0) > > > > > > > > > > > > 2) find the 3D Boolean operations of input objects and > > > > output the > > > > > > presentation by OFF file format. > > > > > > for example, find the unite of two crossed cylinders > > > > and output the > > > > > > presentation by OFF file format. > > > > > > > > > > > > > > > > > > How to implement this with mimimal code? > > > > > > > > > > > > > > > > > > Thanks, > > > > > > Zhanghong Tang > > > > > > > > > > > > > > > > > > P.S.: > > > > > > I notice that the mesher 'NetGen' takes the CSG format > > > > as its input > > > > > > file, however, it can't handle the simplest example (it > > > > works when the > > > > > > radius of two cylinders are not equal), I guess that > > > > the CGAL can handle > > > > > > it easily. > > > > > > > > > > > > > > > > > > > > > > > > > Date: Wed, 18 Jan 2012 08:25:30 +0100 > > > > > > > From: <mailto:> > > > > > > > To: > > > > <mailto:> > > > > > > > Subject: Re: [cgal-discuss] What's the minimal > > > > requirement to use the > > > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > > > > > Zhanghong Tang wrote: > > > > > > > > Dear all, > > > > > > > > > > > > > > > > I would like use the CSG module of CGAL, what's the > > > > minimal > > > > > > requirement > > > > > > > > to use this module? I want to build it to a > > > > blockbox with CSG module > > > > > > > > data input and another format data output (for > > > > example, piecewise > > > > > > linear > > > > > > > > complex format, Geomview's polyhedral file format > > > > (OFF)), which files > > > > > > > > should I select to compile and is there any > > > > interface to use this > > > > > > module? > > > > > > > > > > > > > > > > Thanks, > > > > > > > > Zhanghong Tang > > > > > > > > > > > > > > > Your question is not clear to me. Could you explain > > > > what you are looking > > > > > > > for exactly? > > > > > > &g t; > > > > > > > For 3D Boolean operations, you need to use Nef_3: > > > > > > > > > > > > > > > > > > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html > > > > > > > For simple polyhedron manipulation, you can use > > > > Polyhedron_3: > > > > > > > > > > > > > > > > > > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html > > > > > > > > > > > > > > Sebastien. > > > > > > > ; > > > > > > > -- > > > > > > > You are currently subscribed to cgal-discuss. > > > > > > > To unsubscribe or access the archives, go to > > > > > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > > > > > > > > > > > > > > > > > -- > > > > > You are currently subscribed to cgal-discuss. > > > > > To unsubscribe or access the archives, go to > > > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > > > > > > > > > > > > > > > > -- > > > > =================================================================== > > > > Guillaume DAMIAND > > > > > > > > CNRS, LIRIS UMR 5205 > > > > Université Claude Bernard > > > > Bâtiment Nautibus (710) > > > > 43 Boulevard du 11 Novembre 1918 > > > > 69622 Villeurbanne Cedex (France) > > > > ------------------------------------------------------------------- > > > > Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36 > > > > Mail: > > <mailto:> > > > > =================================================================== > > > > > > > > > > > > > > > > -- > > > > =================================================================== > > > > Guillaume DAMIAND > > > > > > > > CNRS, LIRIS UMR 5205 > > > > Université Claude Bernard > > > > Bâtiment Nautibus (710) > > > > 43 Boulevard du 11 Novembre 1918 > > > > 69622 Villeurbanne Cedex (France) > > > > ------------------------------------------------------------------- > > > > Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36 > > > > Mail: > > <mailto:> > > > > =================================================================== > > > > > > > > > > > > > > > > -- > > > > =================================================================== > > > > Guillaume DAMIAND > > > > > > > > CNRS, LIRIS UMR 5205 > > > > Université Claude Bernard > > > > Bâtiment Nautibus (710) > > > > 43 Boulevard du 11 Novembre 1918 > > > > 69622 Villeurbanne Cedex (France) > > > > ------------------------------------------------------------------- > > > > Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36 > > > > Mail: > > <mailto:> > > > > =================================================================== > > > > > > > > > > > > > -- > > > You are currently subscribed to cgal-discuss. > > > To unsubscribe or access the archives, go to > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss > |
test.zip
Description: Zip archive
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, (continued)
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/24/2012
- Message not available
- FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/25/2012
- Re: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Winnie Hellmann, 01/25/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/25/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/25/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/27/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/27/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/29/2012
- FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/30/2012
- Re: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/30/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/30/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/31/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/30/2012
