RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
- To: <>
- Subject: RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?
- Date: Tue, 31 Jan 2012 02:43:18 +1200
- Importance: Normal
Dear Sebastien,
Thank you very much for your kindly reply. With your great help I read the examples "edge_collapse_polyhedron" and "edge_collapse_enriched_polyhedron" carefully and still confused by the complicated classes defined in CGAL. I still don't know how to simplify the surface mesh defined in the class 'Polyhedron'. Suppose I have the following function, how to fill the code to simplify surface mesh to remove the duplicated vertices with distance less than 1.e-8 and degenerated triangles with area less than 2.220446049250313e-016? void SimplifySurfaceMesh(Polyhedron *P) { double mindis = 1.e-8; double minarea = 2.220446049250313e-016; /// how to simplify surface mesh defined in P? } Thanks > Date: Mon, 30 Jan 2012 08:36:01 +0100 > From: > To: > Subject: Re: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL? > > On 01/30/2012 01:04 AM, Zhanghong Tang wrote: > > Dear all, > > > > Could anyone help me to check my problem? > > > > I use the 3-D geometry boolean operation of CGAL to substract a slot > > (test2.off) from a cylinder (test1.off), the result geometry represented > > by test3.off seems to be not valid for mesh generation. There are many > > duplicated vertices and degenerated facets (facets with area zero). Is > > there any method to avoid that, or is there any check program to correct > > the outputted OFF file? > > > If you work with a Polyhedron, you might want to try that: > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesh_simplification/Chapter_main.html > > with a cost_function related to the size of the edge. > > Sebastien. > > > > Thanks > > > > ------------------------------------------------------------------------ > > From: > > To: > > Date: Mon, 30 Jan 2012 03:04:13 +1200 > > Subject: RE: [cgal-discuss] What's the minimal requirement to use the > > Constructive Solid Geometry (CSG) module of CGAL? > > > > Dear Sebastien, > > > > Thank you very much for point out this for me. Now it works. > > > > I have another question: I have one cylinder (test1.off) and a slot > > (test2.off) be substracted from the cylinder, the result is test3.off. > > > > However, I checked the vertices of test3.off and found that many > > vertices are duplicated. For example: > > 0.06, 0, -0.15 > > 0.06, -2.63531e-017, -0.15 > > > > and > > 0.06, -2.63531e-017, -0.45 > > 0.06, 2.63531e-017, -0.45 > > > > Furthermore, there are many facets look like a line, for example: > > (24, 0, 54) > > > > I guess it is because of the 'exact construction' so the code still > > takes (0.06, 0, -0.15) and (0.06, -2.63531e-017, -0.15) as different > > vertices. Can I set anything in the code to set a 'inexact' threshold > > and let the code combine the duplicated vertices and remove degenerated > > facets? > > > > Thanks > > > > > > > > > > > > > Date: Fri, 27 Jan 2012 08:10:09 +0100 > > > From: > > > To: > > > Subject: Re: [cgal-discuss] What's the minimal requirement to use the > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > (double)vp.x(); is a C-style cast to double and I don't know what is > > > the result. > > > The correct code is CGAL::to_double(vp.x()). > > > > > > Sebastien. > > > > > > On 01/27/2012 07:54 AM, Zhanghong Tang wrote: > > > > Dear all, > > > > > > > > I modified code like this, this time it can run, but got error > > data, for > > > > example, 1.2334234e-300, however, I can output P to OFF file correctly. > > > > could anyone help me to take a look at it? > > > > > > > > Thanks > > > > > > > > > > > > PS: the modified code: > > > > > > > > Polyhedron *P=(Polyhedron *)object->obj; > > > > Point_3 vp; > > > > j=0; > > > > for ( Vertex_iterator v = P->vertices_begin(); v != > > P->vertices_end(); ++v) > > > > { > > > > vp=(Point_3&)v->point(); > > > > doublearray[j++]=(double)vp.x(); > > > > doublearray[j++]=(double)vp.y(); > > > > doublearray[j++]=(double)vp.z(); > > > > } > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > From: > > > > To: > > > > Date: Fri, 27 Jan 2012 17:23:40 +1200 > > > > Subject: RE: [cgal-discuss] What's the minimal requirement to use the > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > Hi Sebastien, > > > > > > > > Thank you very much for point out this problem for me. Now the problem > > > > is solved. However, it is very slow to do union operation when > > there are > > > > many similar objects like this. Is there any more efficient method > > to do > > > > union operation by using CGAL? > > > > > > > > In addition, how to output the coordinates of vertices to an array? The > > > > following code seems to be wrong, how to modify the code? > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > PS: the code to output coordinates of vertices to array > > > > > > > > Polyhedron P=*(Polyhedron *)object->obj; > > > > ... > > > > j=0; > > > > for ( Vertex_iterator v = P.vertices_begin(); v != > > P.vertices_end(); ++v) > > > > { > > > > doublearray[j++]=v->point()->x; > > > > doublearray[j++]=v->point()->y; > > > > doublearray[j++]=v->point()->z; > > > > } > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Date: Wed, 25 Jan 2012 08:53:32 +0100 > > > > > From: > > > > > To: > > > > > Subject: Re: [cgal-discuss] What's the minimal requirement to use the > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > When you provide a face to nef polyhedron, it assumes that the > > points of > > > > > the face lies exactly on a plane. In you example, you have quad-faces > > > > > with non coplanar vertices. > > > > > To solve this issue, you can for example triangulate the faces of > > each > > > > > of your models (see attachement). > > > > > > > > > > Sebastien. > > > > > > > > > > > > > > > > > > > > > > > > > On 01/25/2012 06:26 AM, Zhanghong Tang wrote: > > > > > > Dear all, > > > > > > > > > > > > With the following code, I'd like to add multiple objects into > > one and > > > > > > then output the union to an OFF file, however, the code crashed in > > > > the line > > > > > > Nef_polyhedron nef_obj(obj); > > > > > > > > > > > > how to modify the code to let it works? I will be very > > appericate if > > > > > > anyone help me to check the code. > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > PS: the code > > > > > > > > > > > > typedef struct object > > > > > > { > > > > > > void *obj; > > > > > > }myobj; > > > > > > > > > > > > void UnionObject(myobj *object, void *unionobj, int nobject) > > > > > > { > > > > > > Polyhedron obj, UnitedObj; > > > > > > Nef_polyhedron nef_uni; > > > > > > for (int i=0;i<nobject;i++) > > > > > > { > > > > > > obj=*(Polyhedron *)object[i].obj; > > > > > > Nef_polyhedron nef_obj(obj); > > > > > > if(i==0) > > > > > > nef_uni = nef_obj; > > > > > > else > > > > > > nef_uni = nef_uni + nef_obj; > > > > > > > > > > > > } > > > > > > nef_uni.convert_to_polyhedron(UnitedObj); > > > > > > } > > > > > > > > > > > > There are totally 6 objects to be added, the off files > > generated from > > > > > > object[i].obj (i=0,1,2,3,4,5) are attached. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > From: > > > > > > To: > > > > > > Date: Wed, 25 Jan 2012 15:11:04 +1200 > > > > > > Subject: RE: [cgal-discuss] What's the minimal requirement to > > use the > > > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > > > Hi Guillaume, > > > > > > > > > > > > Thank you very much for your kindly reply. Now I have the following > > > > code > > > > > > to unite many objects into one: > > > > > > > > > > > > typedef struct object > > > > > > { > > > > > > void *obj; > > > > > > }myobj; > > > > > > > > > > > > void UnionObject(myobj *object, void *unionobj, int nobject) > > > > > > { > > > > > > Polyhedron obj, UnitedObj; > > > > > > Nef_polyhedron nef_uni; > > > > > > for (int i=0;i<nobject;i++) > > > > > > { > > > > > > obj=*(Polyhedron *)object[i].obj; > > > > > > Nef_polyhedron nef_obj(obj); > > > > > > if(i==0) > > > > > > nef_uni = nef_obj; > > > > > > else > > > > > > nef_uni = nef_uni + nef_obj; > > > > > > > > > > > > } > > > > > > nef_uni.convert_to_polyhedron(UnitedObj); > > > > > > } > > > > > > > > > > > > However, the program crash in the line > > > > > > Nef_polyhedron nef_obj(obj); > > > > > > > > > > > > Is there any missing to do this? How to modify the code to let the > > > > > > multiple objects be united correctly? > > > > > > > > > > > > I checked the polyhedron obj of every object[i].obj and output > > them to > > > > > > OFF file and they are all correct (under Guillaume's help). > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > From: > > > > > > To: > > > > > > Subject: RE: [cgal-discuss] What's the minimal requirement to > > use the > > > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > Date: Wed, 25 Jan 2012 14:00:22 +1200 > > > > > > > > > > > > Hi Guillaume, > > > > > > > > > > > > Thank you very much for your kindly reply. Now I have the following > > > > code > > > > > > to unite many objects into one: > > > > > > > > > > > > typedef struct object > > > > > > { > > > > > > void *obj; > > > > > > }myobj; > > > > > > > > > > > > void UnionObject(myobj *object, void *unionobj, int nobject) > > > > > > { > > > > > > Polyhedron obj, UnitedObj; > > > > > > Nef_polyhedron nef_uni; > > > > > > for (int i=0;i<nobject;i++) > > > > > > { > > > > > > obj=*(Polyhedron *)object[i].obj; > > > > > > Nef_polyhedron nef_obj(obj); > > > > > > if(i==0) > > > > > > nef_uni = nef_obj; > > > > > > else > > > > > > nef_uni = nef_uni + nef_obj; > > > > > > > > > > > > } > > > > > > nef_uni.convert_to_polyhedron(UnitedObj); > > > > > > } > > > > > > > > > > > > However, the program crash in the line > > > > > > Nef_polyhedron nef_obj(obj); > > > > > > > > > > > > Is there any missing to do this? > > > > > > I checked the polyhedron obj of every object[i].obj and output > > them to > > > > > > OFF file and they are all correct (under Guillaume's help). > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > Date: Tue, 24 Jan 2012 10:20:05 +0100 > > > > > > From: > > > > > > To: > > > > > > Subject: Re: [cgal-discuss] What's the minimal requirement to > > use the > > > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > > > Hi, > > > > > > > > > > > > Hi Guillaume, > > > > > > > > > > > > Thank you very much for your encouragement. I don't understand the > > > > > > benefit to wirte like this: the very complex class, > > constructor, and > > > > > > so on. > > > > > > > > > > > > > > > > > > The benefit is genericity. > > > > > > > > > > > > > > > > > > Is it possible to write just what need to be executed, or the > > > > > > process of execute can be see naturaly. For example: > > > > > > > > > > > > the function: > > > > > > > > > > > > Polyhedron Build_triangle(int nVertices0, double *Vertices0, int > > > > > > nTri0, int *Tri0) > > > > > > { > > > > > > ... > > > > > > } > > > > > > > > > > > > the caller: > > > > > > ... > > > > > > Polyhedron P; > > > > > > P=Build_triangle(nVertices,Vertices,nTri,Tri); > > > > > > > > > > > > > > > > > > No this is not possible: you have to use the format required by the > > > > > > incremental builder class... > > > > > > > > > > > > > > > > > > ... > > > > > > > > > > > > By the way, the following code can output the polyhedron to OFF > > > > > > format to the screen (from the example > > 'polyhedron_prog_cut_cube.cpp'): > > > > > > std::cout << P; > > > > > > > > > > > > how to modify the code to let it output to a file 'filename' with > > > > > > the definition: > > > > > > char *filename; > > > > > > > > > > > > > > > > > > Use ofstream. Cf for example > > > > http://www.cplusplus.com/doc/tutorial/files/ > > > > > > > > > > > > Guillaume > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > Date: Tue, 24 Jan 2012 08:28:50 +0100 > > > > > > From: > > > > > > <mailto:> > > > > > > To: <mailto:> > > > > > > Subject: Re: [cgal-discuss] What's the minimal requirement to use > > > > > > the Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > > > > > > > > > Hi Guillaume, > > > > > > > > > > > > Thank you very much for your kindly reply. Now the problem is > > > > > > solved. I should modify the code like this: > > > > > > > > > > > > > > > > > > Perfect. > > > > > > > > > > > > > > > > > > class Build_triangle : public CGAL::Modifier_base<HDS> { > > > > > > public: > > > > > > int nVertices; > > > > > > double *Vertices; > > > > > > int nTri; > > > > > > int *Tri; > > > > > > Build_triangle(int nVertices0, double *Vertices0, int nTri0, int > > > > > > *Tri0) > > > > > > { > > > > > > nVertices=nVertices0; > > > > > > Vertices=Vertices0; > > > > > > nTri=nTri0; > > > > > > Tri=Tri0; > > > > > > } > > > > > > > > > > > > > > > > > > Now my question is: can I pass parameters as a more simple and > > > > > > understandable way, just like the 'Fortran' subroutine? > > > > > > > > > > > > > > > > > > What do you mean by "more simple and understandable way" ? > > > > > > > > > > > > > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > From: <mailto:> > > > > > > To: > > > > > > <mailto:> > > > > > > Date: Tue, 24 Jan 2012 19:02:57 +1200 > > > > > > Subject: RE: [cgal-discuss] What's the minimal requirement to > > > > > > use the Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > > > Hi Guillaume, > > > > > > > > > > > > Thank you very much for your kindly reply. I am new to C++ class > > > > > > and the complex operators and don't know how to modify the code > > > > > > to pass the parameters to the operator. Is there any simple way > > > > > > to read the input vertices and facets from other functions to > > > > > > form the polyhedron of CGAL? To let the CGAL do boolean > > > > > > operations, should I do like the example? What's the simplest > > > > > > way? I need to generate polyhedron from CSG and then let CGAL to > > > > > > do the boolean opearations and then output the results to OFF file. > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > Date: Tue, 24 Jan 2012 07:09:53 +0100 > > > > > > From: > > > > > > <mailto:> > > > > > > To: > > > > > > <mailto:> > > > > > > Subject: Re: [cgal-discuss] What's the minimal requirement to > > > > > > use the Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > > > The variables nVertices,Vertices,nTri,nTri are parameters of the > > > > > > constructor of your class. > > > > > > Thus they are not defined in the operator(). You need to define > > > > > > variables in your class in order to store them. > > > > > > Guillaume > > > > > > > > > > > > > > > > > > Dear Dr. Loriot, > > > > > > > > > > > > Thank you very much for your kindly reply. I am trying to > > > > > > study the example 'polyhedron_prog_incr_builder' and tried > > > > > > to modify the file 'polyhedron_prog_incr_builder.cpp' as > > > > > > follows: > > > > > > > > > > > > /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// > > > > > > > > > > > > #include <CGAL/Simple_cartesian.h> > > > > > > #include <CGAL/Polyhedron_incremental_builder_3.h> > > > > > > #include <CGAL/Polyhedron_3.h> > > > > > > > > > > > > // A modifier creating a triangle with the incremental builder. > > > > > > template <class HDS> > > > > > > class Build_triangle : public CGAL::Modifier_base<HDS> { > > > > > > public: > > > > > > Build_triangle(int nVertices, double *Vertices, int nTri, > > > > > > int *Tri) {} > > > > > > void operator()( HDS& hds) { > > > > > > // Postcondition: `hds' is a valid polyhedral surface. > > > > > > CGAL::Polyhedro n_incremental_builder_3<HDS> B( hds, true); > > > > > > B.begin_surface( 3, 1, 6); > > > > > > typedef typename HDS::Vertex Vertex; > > > > > > typedef typename Vertex::Point Point; > > > > > > double *v=Vertices; > > > > > > for (int i=0;i<nVertices;i++) > > > > > > B.add_vertex( Point( *v++, *v++, *v++)); > > > > > > for (int i=0;i<nTri;i++) > > > > > > { > > > > > > B.begin_facet(); > > > > > > B.add_vertex_to_facet( *Tri++); > > > > > > B.add_vertex_to_facet( *Tri++); > > > > > > B.add_vertex_to_facet( *Tri++); > > > > > > B.end_facet(); > > > > > > } > > > > > > B.end_surface(); > > > > > > } > > > > > > }; > > > > > > > > > > > > typedef CGAL::Simple_cartesian<double> Kernel; > > > > > > typedef CGAL::Polyhedron_3<Kernel> Polyhedron; > > > > > > typedef Polyhedron::HalfedgeDS HalfedgeDS; > > > > > > > > > > > > int main() { > > > > > > ; Polyhedron P; > > > > > > int nVertices=3; > > > > > > double Vertices[]={0, 0, 0,1, 0, 0,0, 1, 0}; > > > > > > int nTri=1; > > > > > > int Tri[]={0,1,2}; > > > > > > Build_triangle<HalfedgeDS> > > > > > > triangle(nVertices,Vertices,nTri,Tri); > > > > > > P.delegate( triangle); > > > > > > //CGAL_assertion( P.is_triangle( P.halfedges_begin())); > > > > > > return 0; > > > > > > } > > > > > > > > > > > > > > > > > > /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// > > > > > > > > > > > > > > > > > > The following errors displayed: > > > > > > 1>------ Build started: Project: > > > > > > polyhedron_prog_incr_builder, Configuration: Debug Win32 ------ > > > > > > 1>Build started 2012/1/24 11:50:26. > > > > > > 1>InitializeBuildStatus: > > > > > > 1> Touching > > > > > > > > "polyhedron_prog_incr_builder.dir\Debug\polyhedron_prog_incr_builder > > > > > > .unsuccessfulbuild". > > > > > > 1>CustomBuild: > > > > > > 1> All outputs are up-to-date. > > > > > > 1>ClCompile: > > > > > > 1> polyhedron_prog_incr_builder.cpp > > > > > > > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(16): > > > > > > error C2065: 'Vertices' : undeclared identifier > > > > > > 1> > > > > > > > > > > > > D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(10) > > > > > > : while compiling class template member function 'void > > > > > > Build_triangle<HDS>::operator ()(HDS &)' > > > > > > 1> with > > > > > > 1> [ > > > > > > 1> HDS=HalfedgeDS > > > > > > 1> ] > > > > > > 1> > > > > > > > > > > > > D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(41) > > > > > > : see reference to class template instantiation > > > > > > 'Build_triangle<HDS>' being compiled > > > > > > 1> with > > > > > > 1> [ > > > > > > 1> HDS=HalfedgeDS > > > > > > 1> ] > > > > > > > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(17): > > > > > > error C2065: 'nVertices' : undeclared identifier > > > > > > > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(19): > > > > > > error C2065: 'nTri' : undeclared identifier > > > > > > > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(22): > > > > > > error C2065: 'Tri' : undeclared identifier > > > > > > > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\polyhedron_prog_incr_builder.cpp(23): > > > > > > error C2065: 'Tri' : undeclared identifier > > > > > > 1>D:\CGAL\CGAL3.9\CGAL-3.9\examples\Polyhedron\poly > > > > > > hedron_prog_incr_builder.cpp(24): error C2065: 'Tri' : > > > > > > undeclared identifier > > > > > > 1> > > > > > > 1>Build FAILED. > > > > > > 1> > > > > > > 1>Time Elapsed 00:00:02.53 > > > > > > ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 > > > > > > skipped ========== > > > > > > > > > > > > > > > > > > Could you please help me to check the problem? > > > > > > > > > > > > > > > > > > > > > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > > Date: Wed, 18 Jan 2012 11:55:11 +0100 > > > > > > > From: <mailto:> > > > > > > > To: > > > > > > <mailto:> > > > > > > > Subject: Re: [cgal-discuss] What's the minimal > > > > > > requirement to use the Constructive Solid Geometry (CSG) > > > > > > module of CGAL? > > > > > > > > > > > > > > CGAL cannot handle directly cylinders but only discrete > > > > > > polyhedral models. > > > > > > > > > > > > > > See the documentation of Nef package for more details: > > > > > > > > > > > > > > > > > > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html > > > > > > > > > > > > > > Sebastien. > > > > > > > > > > > > > > On 01/18/2012 10:41 AM, Zhanghong Tang wrote: > > > > > > > > Dear Dr. Loriot, > > > > > > > > > > > > > > > > Thank you very much for your kindly reply. > > > > > > > > > > > > > > > > My requirement is as follows: > > > > > > > > 1) read the geometries to do the operations; > > > > > > > > for example, two cylinders with both radius 1 and > > > > > > length 10, the center > > > > > > > > of top and bottom facet of two cylinders are: > > > > > > > > cylinder 1: > > > > > > > > top facet: (0,0,5) > > > > > > > > bottom facet: (0,0,-5) > > > > > > > > cylinder 2: > > > > > > > > top facet (5,0,0) > > > > > > > > bottom facet: (-5,0,0) > > > > > > > > > > > > > > > > 2) find the 3D Boolean operations of input objects and > > > > > > output the > > > > > > > > presentation by OFF file format. > > > > > > > > for example, find the unite of two crossed cylinders > > > > > > and output the > > > > > > > > presentation by OFF file format. > > > > > > > > > > > > > > > > > > > > > > > > How to implement this with mimimal code? > > > > > > > > > > > > > > > > > > > > > > > > Thanks, > > > > > > > > Zhanghong Tang > > > > > > > > > > > > > > > > > > > > > > > > P.S.: > > > > > > > > I notice that the mesher 'NetGen' takes the CSG format > > > > > > as its input > > > > > > > > file, however, it can't handle the simplest example (it > > > > > > works when the > > > > > > > > radius of two cylinders are not equal), I guess that > > > > > > the CGAL can handle > > > > > > > > it easily. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Date: Wed, 18 Jan 2012 08:25:30 +0100 > > > > > > > > > From: <mailto:> > > > > > > > > > To: > > > > > > <mailto:> > > > > > > > > > Subject: Re: [cgal-discuss] What's the minimal > > > > > > requirement to use the > > > > > > > > Constructive Solid Geometry (CSG) module of CGAL? > > > > > > > > > > > > > > > > > > Zhanghong Tang wrote: > > > > > > > > > > Dear all, > > > > > > > > > > > > > > > > > > > > I would like use the CSG module of CGAL, what's the > > > > > > minimal > > > > > > > > requirement > > > > > > > > > > to use this module? I want to build it to a > > > > > > blockbox with CSG module > > > > > > > > > > data input and another format data output (for > > > > > > example, piecewise > > > > > > > > linear > > > > > > > > > > complex format, Geomview's polyhedral file format > > > > > > (OFF)), which files > > > > > > > > > > should I select to compile and is there any > > > > > > interface to use this > > > > > > > > module? > > > > > > > > > > > > > > > > > > > > Thanks, > > > > > > > > > > Zhanghong Tang > > > > > > > > > > > > > > > > > > > Your question is not clear to me. Could you explain > > > > > > what you are looking > > > > > > > > > for exactly? > > > > > > > > &g t; > > > > > > > > > For 3D Boolean operations, you need to use Nef_3: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html > > > > > > > > > For simple polyhedron manipulation, you can use > > > > > > Polyhedron_3: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html > > > > > > > > > > > > > > > > > > Sebastien. > > > > > > > > > ; > > > > > > > > > -- > > > > > > > > > You are currently subscribed to cgal-discuss. > > > > > > > > > To unsubscribe or access the archives, go to > > > > > > > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > > You are currently subscribed to cgal-discuss. > > > > > > > To unsubscribe or access the archives, go to > > > > > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > =================================================================== > > > > > > Guillaume DAMIAND > > > > > > > > > > > > CNRS, LIRIS UMR 5205 > > > > > > Université Claude Bernard > > > > > > Bâtiment Nautibus (710) > > > > > > 43 Boulevard du 11 Novembre 1918 > > > > > > 69622 Villeurbanne Cedex (France) > > > > > > ------------------------------------------------------------------- > > > > > > Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36 > > > > > > Mail: > > > > <mailto:> > > > > > > =================================================================== > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > =================================================================== > > > > > > Guillaume DAMIAND > > > > > > > > > > > > CNRS, LIRIS UMR 5205 > > > > > > Université Claude Bernard > > > > > > Bâtiment Nautibus (710) > > > > > > 43 Boulevard du 11 Novembre 1918 > > > > > > 69622 Villeurbanne Cedex (France) > > > > > > ------------------------------------------------------------------- > > > > > > Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36 > > > > > > Mail: > > > > <mailto:> > > > > > > =================================================================== > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > =================================================================== > > > > > > Guillaume DAMIAND > > > > > > > > > > > > CNRS, LIRIS UMR 5205 > > > > > > Université Claude Bernard > > > > > > Bâtiment Nautibus (710) > > > > > > 43 Boulevard du 11 Novembre 1918 > > > > > > 69622 Villeurbanne Cedex (France) > > > > > > ------------------------------------------------------------------- > > > > > > Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36 > > > > > > Mail: > > > > <mailto:> > > > > > > =================================================================== > > > > > > > > > > > > > > > > > > > > > -- > > > > > You are currently subscribed to cgal-discuss. > > > > > To unsubscribe or access the archives, go to > > > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > > > > > > > > > -- > > > You are currently subscribed to cgal-discuss. > > > To unsubscribe or access the archives, go to > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss > |
- Re: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, (continued)
- Re: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Winnie Hellmann, 01/25/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/25/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/25/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/27/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/27/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/29/2012
- FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/30/2012
- Re: FW: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/30/2012
- RE: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Zhanghong Tang, 01/30/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/31/2012
- Re: [cgal-discuss] What's the minimal requirement to use the Constructive Solid Geometry (CSG) module of CGAL?, Sebastien Loriot (GeometryFactory), 01/30/2012
