- To:
- Subject: Re: [cgal-discuss] compile CGAL
- Date: Mon, 30 Jan 2012 10:30:43 +0600
It's all pretty simple.
In step "3 - Click Configure and then Choose [compiler]" just choose the compiler according to the version of VS you use. For correct choice look at year.
But, of course, you can use any C compiler installed on your PC.
Have a nice day :)
2012/1/30 Sergio NNX <>
Ciao Арсентий Нерушев.
I've successfully built the latest version of CGAL using MinGW. I don't know much about how to do that VS, but I could try!
Cheers.
Sergio.
Date: Sun, 29 Jan 2012 21:54:13 +0600
To:
Are you sure you've chosen "Visual Studio 2008" as working compiler? Because this message "Check for working C compiler using: Visual Studio 8 2005" means that you've chosen the compiler for Visual Studio 2005. I think you've might mix it up.
2012/1/29 Zeineb Abderrahim <>I am a new user of CGAL. I have not been able to compile CGAL. I followed the following steps :1 - Open CMake - cmake-gui
2 - For both "Where is the source code" and "Where to build the binaries" Specify the CGAL installation folder (C: / Program Files/CGAL-3.7)
3 - Click Configure and then Choose "Visual Studio 2008
I found this in the compilation :Check for working C compiler using: Visual Studio 8 2005Check for working C compiler using: Visual Studio 8 2005 -- brokenCMake Error at C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE):The C compiler "cl" is not able to compile a simple test program.It fails with the following output:Change Dir: C:/Program Files/CGAL-3.8/CMakeFiles/CMakeTmpRun Build Command:C:\PROGRA~1\MICROS~4\Common7\IDE\VCExpress.exeCMAKE_TRY_COMPILE.sln /build Debug /project cmTryCompileExecMicrosoft (R) Visual C++ Express Version 8.0.50727.867.Copyright (C) Microsoft Corp 1984-2005. Tous droits réservés.1>------ Dbut de la gnrationÿ: Projetÿ: cmTryCompileExec,Configurationÿ: Debug Win32 ------1>Compilation en cours...1>Compilateur d'optimisation Microsoft (R) 32ÿbits C/C++versionÿ14.00.50727.762 pour 80x861>Copyright (C) Microsoft Corporation. Tous droits rservs.1>cl /Od /D "WIN32" /D "_WINDOWS" /D "_DEBUG" /D "CMAKE_INTDIR=\"Debug\""/D "_MBCS" /FD /RTCs /MDd /Fo"cmTryCompileExec.dir\Debug\\" /Fd"C:\ProgramFiles\CGAL-3.8\CMakeFiles\CMakeTmp\Debug/cmTryCompileExec.pdb" /W3 /c /Zi/TC /Zm10001> ".\testCCompiler.c"1>testCCompiler.c1>Compilation du manifeste en ressources en cours...1>dition des liens en cours...1>LINK : fatal error LNK1104: impossible d'ouvrir le fichier 'user32.lib'1>Le journal de gnration a t enregistr … l'emplacement"file://c:\ProgramFiles\CGAL-3.8\CMakeFiles\CMakeTmp\cmTryCompileExec.dir\Debug\BuildLog.htm"1>cmTryCompileExec - 1 erreur(s), 0 avertissement(s)========== Gnrationÿ: 0 a russi, 1 a chou, 0 mis … jour, 0 a tignor ==========CMake will not be able to correctly generate this project.Call Stack (most recent call first):CMakeLists.txt:6 (project)Configuring incomplete, errors occurred!Please what is the problem ???Thanks
Арсентий Нерушев
Арсентий Нерушев
- [cgal-discuss] compile CGAL, Zeineb Abderrahim, 01/29/2012
- Re: [cgal-discuss] compile CGAL, Арсентий Нерушев, 01/29/2012
- RE: [cgal-discuss] compile CGAL, Sergio NNX, 01/29/2012
- Re: [cgal-discuss] compile CGAL, Arsenty Nerushev, 01/30/2012
- Re: [cgal-discuss] compile CGAL, Laurent Saboret, 01/30/2012
