- To:
- Subject: [cgal-discuss] Re: Setting Supports_removal and other flags in Polyhedron_3
- Date: Sun, 29 Jan 2012 20:45:07 -0800 (PST)
Ah, I found out why Polyhedron_3::Supports_removal was set to false. I had
stupidly used CGAL::HalfedgeDS_vector instead of the default list
implementation CGAL::HalfedgeDS_list.
Correct me if I'm wrong, but I think that if I wanted to modify these, I
would have to create my own class inheriting from Polyhedron_3, and then
modify the tags from there.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Setting-Supports-removal-and-other-flags-in-Polyhedron-3-tp4339946p4340060.html
- [cgal-discuss] Setting Supports_removal and other flags in Polyhedron_3, freckles, 01/30/2012
- [cgal-discuss] Re: Setting Supports_removal and other flags in Polyhedron_3, freckles, 01/30/2012
- Re: [cgal-discuss] Re: Setting Supports_removal and other flags in Polyhedron_3, Sebastien Loriot (GeometryFactory), 01/30/2012
