Re: [cgal-discuss] Re: Setting Supports_removal and other flags in Polyhedron_3
- To:
- Subject: Re: [cgal-discuss] Re: Setting Supports_removal and other flags in Polyhedron_3
- Date: Mon, 30 Jan 2012 08:41:07 +0100
On 01/30/2012 05:45 AM, freckles wrote:
Ah, I found out why Polyhedron_3::Supports_removal was set to false. I had
stupidly used CGAL::HalfedgeDS_vector instead of the default list
implementation CGAL::HalfedgeDS_list.
Correct me if I'm wrong, but I think that if I wanted to modify these, I
would have to create my own class inheriting from Polyhedron_3, and then
modify the tags from there.
I don't get your question. The Polyhedron based on hds_list has the removal feature. So what do you want to do exactly?
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Setting-Supports-removal-and-other-flags-in-Polyhedron-3-tp4339946p4340060.html
- [cgal-discuss] Setting Supports_removal and other flags in Polyhedron_3, freckles, 01/30/2012
- [cgal-discuss] Re: Setting Supports_removal and other flags in Polyhedron_3, freckles, 01/30/2012
- Re: [cgal-discuss] Re: Setting Supports_removal and other flags in Polyhedron_3, Sebastien Loriot (GeometryFactory), 01/30/2012
