- To:
- Subject: Re: [cgal-discuss] sweep line
- Date: Wed, 01 Feb 2012 17:21:12 +0100
This means that for each functor of each TraitsOk, I see. That would be quite a bit of work. Thank you for pointing that out!
(linear, circular, bezier,...) you need to do that job of
refactorization.
The documentation is correct:I did not know that concepts can "inherit". Will there some time in the near future be checking of the concepts in CGAL, e.g. using the boost Concept Checks [1]?
Arr_linear_traits_2 is said to model concept ArrangementTraits_2 which
refines ArrangementXMonotoneTraits_2.
[1] http://www.boost.org/doc/libs/1_35_0/libs/concept_check/using_concept_check.htm
- Re: [cgal-discuss] sweep line, Sebastien Loriot (GeometryFactory), 02/01/2012
- Re: [cgal-discuss] sweep line, Winnie Hellmann, 02/01/2012
- Re: [cgal-discuss] sweep line, Philipp Moeller, 02/01/2012
